discovery 1 build
Pieter_Macdonald
Grease Monkey
discovery 1 build
#1 Post by Pieter_Macdonald » Wed Mar 11, 2020 10:25 pm
I have recently acquired 2 discovery 1's from my dad, one with a v8 (the green one) and the other with a 300 tdi and 5 speed r380 transmission with a salvage title (the blue one). I plan to convert the green one to a 300 tdi with the parts from the other truck.
(477.61 KiB) Downloaded 377 times
(444.55 KiB) Downloaded 376 times
(425.38 KiB) Downloaded 381 times
So far I have removed both motors and torn the interior out of the green truck as I plan on repainting it. Unfortunately, but not surprisingly I have also discovered (no pun intended) :D quite a bit of rust that will need to be repaired before I put in the new motor.
(547.87 KiB) Downloaded 374 times
Some fun but unnecessary things I've done are put the steel wheels on and start on a stainless steel raised air intake.
(301.85 KiB) Downloaded 378 times
I will add to this forum as progress continues.
rgallant
Cylinder bore
Re: discovery 1 build
#2 Post by rgallant » Thu Mar 12, 2020 12:20 pm
Be interesting to see how this goes, good luck
bclandrover
#3 Post by bclandrover » Thu Mar 12, 2020 9:07 pm
//uploads.tapatalk-cdn.com/202003 ... 3b20bc.jpg
I swear I didn’t put him up to this!!
rgallant
Cylinder bore
#4 Post by rgallant » Thu Mar 12, 2020 11:01 pm
Great picture!
BjornErickson
Newbie
#5 Post by BjornErickson » Fri Mar 13, 2020 9:24 pm
this is what I hope to do one day cant wait to see how it turns out!
Pieter_Macdonald
Grease Monkey
#6 Post by Pieter_Macdonald » Sun Mar 22, 2020 10:49 pm
More Progress!!
I have now almost fully taken out the interior and wiring harness.
(488.09 KiB) Downloaded 301 times
I have found more rust in various places which I'm not too happy about, but I've seen worse so I think I got lucky.
(375.03 KiB) Downloaded 306 times
(401 KiB) Downloaded 302 times
There are other rust holes as well but I don't have photos of them.
Pieter_Macdonald
Grease Monkey
#7 Post by Pieter_Macdonald » Sun Mar 22, 2020 11:03 pm
I have now started the task of rust repair. I have taken out the drivers-side inner fender by drilling out many spot welds and peeling away tons of seem sealer Intel it came out. I then made a cardboard template and made a new piece out of fresh metal.
(393.62 KiB) Downloaded 304 times
(392.43 KiB) Downloaded 302 times
(418.71 KiB) Downloaded 304 times
I haven't quite finished it but I got it test fitted in the truck and it sorta fits!!
TylerN
Crank Case
#8 Post by TylerN » Sat Aug 28, 2021 6:33 pm
Whatever happened to this build? I’d love to see more!
