D90 rear tub trailer
LandyAndy
Maxi Drive
#1 Post by LandyAndy » Fri Aug 03, 2018 5:35 pm
Been toying with the idea of building the spare D90 tub I have into a little expo style trailer to haul behind the D100, mostly because I can't bear to scrap it & it's a PITA to keep moving around by myself...
This is the tub as it came off...
I have a length of tub top to make a closing panel for the front & I can modify the hood to have a window in the front & a cover over the little front box. Also have the old swing away spare carrier for the back too.
So, was thinking of using some spindles, hubs & rear disc's & calipers along with a hydraulic surge brake coupler to keep it simple & retain the LR lug patten.... welded onto a 3" tube for the axle.
Shocks prob some Pro Comps or similar.
Thoughts.....
(61.52 KiB) Downloaded 115 times
(57.78 KiB) Downloaded 112 times
terayon
Swivel Ball
Re: D90 rear tub trailer
#2 Post by terayon » Fri Aug 03, 2018 6:00 pm
Hi Andy,
I was planning on doing the same thing with a 109 tub... there was one in Vic a little while ago. I ended up buying a bantam army trailer from the 50's, it was $300 so you cant go wrong. It needed about $70 in parts and I'll rattle can it grey to match my rover.
I am upgrading my springs to parablics, courtesy of Jeremy at Rocky Mountain. If you'd like you are welcome to my old Springs once I'm done.
I'm located on the island and interested in seeing more pics as the project continues.
Jordan
Sent from my SM-N950W using Tapatalk
LandyAndy
Maxi Drive
#3 Post by LandyAndy » Sun Aug 05, 2018 9:04 am
Hi Jordan,
Thanks for the offer, what are they off ?
Will be on the island in Sept so could pick up then.
terayon
Swivel Ball
#4 Post by terayon » Mon Aug 06, 2018 8:07 am
They are off my '63 109 stationwagon.
LandyAndy
Maxi Drive
#5 Post by LandyAndy » Sat Feb 18, 2023 1:37 pm
This project has been on the back burner for a long time, made a bit of progress last year by building a frame & axle that uses stock LR axle stub shafts.
Did a bit more over Christmas and drew up the caliper brackets & some end caps for the hubs. Have most parts to get it to a roller stage this spring.
(163.89 KiB) Downloaded 112 times
(155.95 KiB) Downloaded 114 times
(158.01 KiB) Downloaded 112 times
(194.08 KiB) Downloaded 113 times
(177.39 KiB) Downloaded 110 times
LandyAndy
Maxi Drive
#6 Post by LandyAndy » Sun Jun 25, 2023 9:07 pm
Getting this finished for its new owner.
(151.02 KiB) Downloaded 77 times
(168.78 KiB) Downloaded 78 times
(153.01 KiB) Downloaded 78 times
(140.07 KiB) Downloaded 76 times
(119.65 KiB) Downloaded 75 times
LandyAndy
Maxi Drive
#7 Post by LandyAndy » Thu Jul 06, 2023 5:04 pm
Finished up the capping on the front panel & also got the hood extension made out of some spare material. Next to pull the tub back off & finish the frame.
(106.63 KiB) Downloaded 42 times
(104.25 KiB) Downloaded 41 times
LandyAndy
Maxi Drive
#8 Post by LandyAndy » Sat Jul 15, 2023 12:32 pm
Painting time !
Brushed on the primer for a thicker coat.
(140.92 KiB) Downloaded 32 times
Then hit it with the rattle cans of high build chassis enamel.
(179.71 KiB) Downloaded 32 times
(274.16 KiB) Downloaded 35 times
