various 2.5NA parts
radio_05
Gently Used Condition
various 2.5NA parts
#1 Post by radio_05 » Thu Mar 15, 2018 7:21 pm
I also have many 2.5 Diesel injection pumps, heads, injectors, blocks and cranks for sale. Contact me if needing any used 2.5 parts.
joshallen676
Newbie
Re: various 2.5NA parts
#2 Post by joshallen676 » Mon Mar 19, 2018 3:18 am
Would any of the parts fit a 2.25?
Josh
radio_05
#3 Post by radio_05 » Sat Mar 31, 2018 8:51 am
None would fit a 2.25.
Horn Blower
#4 Post by HeadDamage » Sat Mar 31, 2018 1:18 pm
That depends if it is a 3 or 5 main to some extent. A surprising number of parts swap between all the way from the 2.25 up to the 200tdi.
radio_05
#5 Post by radio_05 » Sat Mar 31, 2018 9:23 pm
I have a few full sets of disassembled 2.5 NA. If you can find the common part numbers you're after, let me know, and i'll tell you if I have it. I do know a guy who has a cracked-block 2.25 gas engine. He may want to sell that to you. I could sell you 2.5 NA parts, but i'm unsure how that would move you ahead on your 2.25 diesel rebuild.
Horn Blower
#6 Post by HeadDamage » Sat Mar 31, 2018 9:39 pm
You can build a nice 2.5L gas motor using the diesel block, crank, con rods, pistons, camshaft and mixing that with the gas timing parts and casing and the gas head.
Tofu86
#7 Post by Tofu86 » Wed Apr 11, 2018 5:21 pm
Do you happen to have a later style oil pump, part number err1117? It's the oil pump with an additional external bracket holding the filter. Thanks.
radio_05
#8 Post by radio_05 » Thu Apr 19, 2018 7:41 pm
Yes, I do have several of those pumps. I will send you a PM
