various 2.5NA parts
Forum rules
radio_05
- Gently Used Condition
various 2.5NA parts
I also have many 2.5 Diesel injection pumps, heads, injectors, blocks and cranks for sale. Contact me if needing any used 2.5 parts.
joshallen676
- Newbie
Re: various 2.5NA parts
Would any of the parts fit a 2.25?
Josh
Josh
radio_05
None would fit a 2.25.
- Horn Blower
That depends if it is a 3 or 5 main to some extent. A surprising number of parts swap between all the way from the 2.25 up to the 200tdi.
radio_05
I have a few full sets of disassembled 2.5 NA. If you can find the common part numbers you're after, let me know, and i'll tell you if I have it. I do know a guy who has a cracked-block 2.25 gas engine. He may want to sell that to you. I could sell you 2.5 NA parts, but i'm unsure how that would move you ahead on your 2.25 diesel rebuild.
- Horn Blower
You can build a nice 2.5L gas motor using the diesel block, crank, con rods, pistons, camshaft and mixing that with the gas timing parts and casing and the gas head.
Tofu86
Do you happen to have a later style oil pump, part number err1117? It's the oil pump with an additional external bracket holding the filter. Thanks.
radio_05
Yes, I do have several of those pumps. I will send you a PM
