LEDs
obalme
- Crank Case
LEDs
Just installed new LED turn signals, brake lights, parking lights and a Number plate light. They look really nice!
http://i350.photobucket.com/albums/q401/colinbalme/D4EA284F-1883-4B2C-80DD-E8F1874B2410_zpsd1cjlyri.jpg
(Excuse the rusted rear crossmember)
I had a lot of trouble installing them, I had to make new connections since they were meant for a newer truck and I spent quite a while thinking they were duds until I checked my grounds and tested them with a 9v battery. I had an issue where both turn signals came on at the same time, but I had read somewhere else that if you removed the bulb in the dash it fixed the problem. (It did fix the problem) I also read that if you replace the bulb in the dash with a LED it fixes the problem, does anyone know where I can find one?
Oliver
Oliver
obalme
- Crank Case
Re: LEDs
I got them off of paddock spares, they're the WIPAC ones who I think are the maker of the normal Defender lights.
http://www.paddockspares.com/standard-s ... lamps.html
http://www.paddockspares.com/led-number-plate-lamp.html
They also have ones with clear lenses but I prefer the standard look on my truck.
I forgot to mention that I also had to drill two new holes for each light, other trucks may vary.
Re: LEDs
The low cost solution is to fit load resistors. You should be able to get those at an auto parts store. Fixing the problem at the dash indicator is fairly complicated. See post 8 here: https://www.landyzone.co.uk/land-rover/ ... it.273205/ for how that would be achieved.
Re: LEDs
I just saw that RDX makes a plug and play solution. http://www.ebay.co.uk/itm/RDX-Earth-Fix ... 361500fb5c
