Carb fittings. Series 1
rayhyland
- Drip Dry
Hi everyone, does anyone know if the banjo fittings on a cheap Chinese knock off of the Solex carb will fit the threads on an original Solex?
The Chinese carb I have has failed here in Istanbul on our trip and I am considering ordering the original from Dunsfold but I don't know if I also need to order the fittings, or if they even have the fittings.
Thanks!
Ray
//images.tapatalk-cdn.com/15/11/21 ... bbe724.jpg
Thanks!
Ray
S3ute
- Beyond Recovery
Re: Carb fittings. Series 1
Ray,
Hello from Delhi.
Can't answer your specific question about the fittings but given your situation if you want a quick answer from people who do then log onto the Australian Land Rover Owners site (AULRO.com). Wealth of knowledge in there and fast turn around time on responses.
Neil
Hello from Delhi.
Neil
tony
Hello Hyland family, I hope you are all doing well and you get the carb problem fixed soon. Please do keep us all up to date on your progress, good to hear from you.
I hope its not as cold camping in Turkey as it is here right now. :D
rayhyland
- Drip Dry
Thanks Tony! Changed the carb, but still have the same problem. So no idea what the issue is but I'm going to try to track it down before we leave Istanbul.
tony
Hows the coil? or the distributor? or maybe crap plugging the fuel line at the source way before the filter?
rayhyland
- Drip Dry
Pulled a big chunk of silicon out of the line going into the fuel filter. Matches the silicon holding the sender unit in the tank. Also put in bigger jets. Distributor seems ok. Not sure how to check the coil.
tony
Against your spare :D
S3ute
- Beyond Recovery
Hello again.rayhyland wrote:Not sure how to check the coil.
Try this simple spark plug test:
http://www.doityourself.com/stry/how-to ... -a-vehicle
P.S. Saw your trip featured in the most recent issue of Land Rover Classic.
If you stuck with my fuel pump setup there is a second filter before the pump, so check that one as well
rayhyland
- Drip Dry
Hi Jake, I found a huge piece of Orange silicon in that filter so that may have been a contributing factor. :-)
No warranties expressed or implied!
It might not be the last piece of silicone you find. I was generous.
