Spring (Shackle ) Bushings
Richard Elson
My parts manual says that the bushings for the rear spring shackle (Chassis side) should be either 1.187 OD or the regular 1.5. I mic'd the opening and it is about 1.040 - 1.080 that is front and rear (chassis side). What's up? Anyone have a crossover part number for a domestic auto. I was told to go to the axle/spring shop and just give them the dimensions I need.
Richard Elson
Shackle Bushings
I thought I would answer myself as this may come up for someone else. When I took the old bushings out (Too long ago to remember what I did) I left the outer casing of the bushing in. It was so rusted in that until I looked very closely with good light I could not tell that I had not cleaned it out properly. That was the difference in size.
Someone mentioned poly ones give a real rough ride. Anyone have poly in theirs? I usd to poly engine mounts in customized vws and there were 2 grades of hardness. The medium grade was great, but the hard grade moved all vibration of the engine to the chassis.
I kind of like the looks of these greasable poly ones:
http://www.gon2far.co.uk/gallery/parts/500_bolts2.jpg
from GON2FAR
from GON2FAR
