While laying in a puddle of oil last night changing out a broken short side half shaft that I quite nicely sheared in two, I got to thinking about a product that I think I have seen for sale somewhere. I think I read about someone who was producing a drive flange that had a friction device in it that would slip if a designed torque load was exceeded thereby saving your half shafts from breaking.
I have been unable to find such a product on the net and am curious if anyone else has run into such a thing.
Thanks for your help!
-Ryan
Torque limiting drive flanges?
Revor
- Muddy Tyres
reefworld1
drive info
Hi, I beleive I saw them at drive products on 96th ave in port kells. They are special bolts & drive flange assembly ( I think they called them fuses ) that connected the drive line that would break and allow the drive line to rotate on its alignment shaft at a preselected torque. The driveline doesn't drop off when the fuses let go & The fuses are easily replaced.
rick.m
snap! snap!!
some of the very best advice i got when o broke my only brand new oem rear short axle. on a 65 IIA . was" PUT IN A SALSBURY. " and i have lived happily ever after. rick.m
cheap still
cheap still
