Landrover at B.C. Hydro Bus Shops
RobinS
Over Inflated
#1 Post by RobinS » Sun Jul 09, 2023 5:40 am
I was going through some old photo albums recently and discovered these two shots I took in the mid 1980's at B.C. Hydro's bus maintenance facility in Victoria. That's my series one in the background. I never found out what it was used for , maybe someone remembers. An interesting old Landrover any way and I'm glad I snapped these pics before it was lost to history.
(24.47 KiB) Downloaded 145 times
(29.42 KiB) Downloaded 147 times
RobinS
Over Inflated
Re: Landrover at B.C. Hydro Bus Shops
#2 Post by RobinS » Sun Jul 09, 2023 5:43 am
Sorry about this , I don't know why they are sideways nor do I know how to fix it . Cheers Robin
#3 Post by bsa_m21 » Sun Jul 09, 2023 3:46 pm
FYI
Many modern phone photo apps auto sense and rotate the image for you. Unfortunately the forum doesn’t do it.
If you open the image for editing on your pc or Mac, you an manually rotate and save it. It will then display correctly when you upload to the forum.
RobinS
Over Inflated
#4 Post by RobinS » Mon Jul 10, 2023 5:46 am
I will try again
(24.37 KiB) Downloaded 115 times
(28.85 KiB) Downloaded 115 times
RobinS
Over Inflated
#5 Post by RobinS » Mon Jul 10, 2023 5:47 am
I obviously need professional help
Colin
Mud Pit Boss
#6 Post by Colin » Tue Jul 11, 2023 3:19 pm
It was for washing buses, the motor ran a hydraulic pump that both moved the vehicle and ran the pressure washer. I have some pictures as well somewhere.
RobinS
Over Inflated
#7 Post by RobinS » Wed Jul 12, 2023 5:48 am
Thanks Colin , sounds like it was highly modified but that is what Landrover was famous for , the ability to be modified into just about anything.
