Springs.
Glenn D.
Cross Member
Springs.
#1 Post by Glenn D. » Mon Mar 06, 2006 5:39 pm
Ok I've just bought new shocks (OME) and shock towers (tubular galvanized), so I might as well replace the coils on my 90. I want a 1-2 inch lift but still want a comfortable ride. Any recomendations or things I need to worry about? What do you use?
OME lift......
#2 Post by ANDYD » Mon Mar 06, 2006 10:54 pm
Hi Glenn,
Check out the RL FAQ for the OME lift parts;
http://www.roverlanders.bc.ca./faq/faq_OME.html#3
I'm not sure which shocks you bought, but you may need uprated OME shocks if you want a 1 to 2 inch lift? (to match the larger springs).
Cross check your part numbers.
Make sure you take some photos as you install,
Good luck,
PaulC
#3 Post by PaulC » Tue Mar 07, 2006 9:02 am
Hi Glen,
Useful info on OME can be found on the Expedition Exchange webs site as well as our chart.
https://www.expeditionexchange.com/ome/indexsprings.htm
I’ve said it before it’s hard to beat OME price/quality and availability.
