Springs.
Glenn D.
- Cross Member
Springs.
Ok I've just bought new shocks (OME) and shock towers (tubular galvanized), so I might as well replace the coils on my 90. I want a 1-2 inch lift but still want a comfortable ride. Any recomendations or things I need to worry about? What do you use?
OME lift......
Hi Glenn,
Check out the RL FAQ for the OME lift parts;
http://www.roverlanders.bc.ca./faq/faq_OME.html#3
I'm not sure which shocks you bought, but you may need uprated OME shocks if you want a 1 to 2 inch lift? (to match the larger springs).
Cross check your part numbers.
Make sure you take some photos as you install,
Good luck,
Good luck,
PaulC
Hi Glen,
Useful info on OME can be found on the Expedition Exchange webs site as well as our chart.
https://www.expeditionexchange.com/ome/indexsprings.htm
I’ve said it before it’s hard to beat OME price/quality and availability.
