Where does this part go?
Arcades
Captain Crunch
#1 Post by Arcades » Thu Feb 11, 2021 3:05 pm
So this part fell off my truck yesterday... Can anyone tell me where it belongs?
(501.98 KiB) Downloaded 672 times
Re: Where does this part go?
#2 Post by bsa_m21 » Thu Feb 11, 2021 5:15 pm
Why in my garage, of course! 🤗
Horn Blower
#3 Post by HeadDamage » Thu Feb 11, 2021 8:07 pm
You don't want that, it will not run worth a dam on diesel ;)
Arcades
Captain Crunch
#4 Post by Arcades » Thu Feb 11, 2021 9:57 pm
My thoughts exactly!
Arcades
Captain Crunch
#5 Post by Arcades » Thu Feb 11, 2021 10:03 pm
(561.96 KiB) Downloaded 640 times
(527.83 KiB) Downloaded 641 times
Well now I don't have to worry about fuel at all anymore
Arcades
Captain Crunch
#6 Post by Arcades » Thu Feb 11, 2021 10:05 pm
(451.69 KiB) Downloaded 650 times
But look at my lift now... To think all I needed to do was take out the brick.
#7 Post by ANDYD » Tue Feb 16, 2021 1:19 pm
Hey Mark,
Finally time for that Electric Conversion? Where will you put the 18 batteries? :wink:
Arcades
Captain Crunch
#8 Post by Arcades » Fri Feb 19, 2021 10:56 pm
I just want to pay back everything that I got from you guys.... mainly the diesel exhaust fumes!
acg
Cylinder bore
#9 Post by acg » Sat Feb 20, 2021 1:09 pm
Mark,
Are you planning on replacing with V8 with something else? Or simply re-building the existing engine?
Either ways, good luck with the project. Looking forward to seeing you at one of our runs when the weather gets warmer.
Arcades
Captain Crunch
#10 Post by Arcades » Sat Feb 20, 2021 1:29 pm
This is going in....
(453.07 KiB) Downloaded 568 times
(363.54 KiB) Downloaded 565 times
(548.96 KiB) Downloaded 564 times
It's a om606 turbo, a 6l90e transmission and a Ashcroft special transfercase
Tony4921
#11 Post by Tony4921 » Sun Feb 21, 2021 7:45 am
Nice mod. Where did you get the sump for the 606?
Arcades
Captain Crunch
#12 Post by Arcades » Sun Feb 21, 2021 3:26 pm
I met this super nice guy online that had done this conversion more than once (they are the goto non OEM swap in Europe). I ended up shipping all my parts to his place and then he boxed them up and sent them here in a single shipment. Saved a ton of shipping. Also he had great advice.
Arcades
Captain Crunch
#13 Post by Arcades » Sun Feb 21, 2021 3:27 pm
It's from an om648
paulg_d130
Little Wheel
#14 Post by paulg_d130 » Mon Feb 22, 2021 3:42 pm
keenly watching this so bring on the detail!
im toying with the idea of a om648 swap but still in the dreaming stage.
what did your get in your tcase? did you change the high range gears? add the ATB
Arcades
Captain Crunch
#15 Post by Arcades » Tue Feb 23, 2021 2:18 pm
It’s from Ashcroft. I HDed everything I could.. went to a higher gear set and the atb.
Arcades
Captain Crunch
#16 Post by Arcades » Tue Feb 23, 2021 2:26 pm
I figured that with all the torque from the new engine and the fact that I’m running 4.43 diffs I could use a higher gear.
Arcades
Captain Crunch
#17 Post by Arcades » Wed Feb 24, 2021 11:57 am
(553.93 KiB) Downloaded 490 times
In the hole!
#18 Post by bsa_m21 » Wed Feb 24, 2021 6:55 pm
Mark - where are you doing, or getting the work done?
Arcades
Captain Crunch
#19 Post by Arcades » Thu Feb 25, 2021 11:11 am
It's being done at big country customs in Abbotsford. They also made my rear bumper for me amount many other things. They don't say no there.
Arcades
Captain Crunch
#20 Post by Arcades » Thu Mar 25, 2021 11:35 pm
Just a few shots of the progress... should be running in the next few days...
(186.53 KiB) Downloaded 432 times
(204.47 KiB) Downloaded 436 times
(243.02 KiB) Downloaded 436 times
(203.79 KiB) Downloaded 429 times
Arcades
Captain Crunch
#21 Post by Arcades » Thu Mar 25, 2021 11:45 pm
Intercooler pipes and exhaust
(149.39 KiB) Downloaded 429 times
(173.16 KiB) Downloaded 436 times
#22 Post by bsa_m21 » Fri Mar 26, 2021 10:09 am
Sweet! Looking forward to seeing and hearing it. 👍👍
Arcades
Captain Crunch
#23 Post by Arcades » Sat Mar 27, 2021 4:04 pm
Me too... me too
Arcades
Captain Crunch
#24 Post by Arcades » Sat Apr 24, 2021 11:46 am
The engine is now running... I would post a video but it's too large 😢
Arcades
Captain Crunch
#25 Post by Arcades » Sat Apr 24, 2021 11:53 am
Had an issue with the linkage for my transfercase. I had too move it back because of the longer transmission. I didn't want to cut more holes in the floor and cut up my automatic console. I found the solution by following what the English guys are doing when they swap Cummins in... Often they put in larger transmissions including alisons! They go with a pneumatic system.. maybe an alternative for the disco guys who want to put CDL in....
