109
troy
Maxi Drive
109
#1 Post by troy » Tue Sep 22, 2020 7:45 am
(179.86 KiB) Downloaded 238 times
(192.7 KiB) Downloaded 238 times
(178.4 KiB) Downloaded 238 times
(153.66 KiB) Downloaded 238 times
(193.24 KiB) Downloaded 238 times
troy
Maxi Drive
Re: 109
#2 Post by troy » Tue Sep 22, 2020 7:51 am
(179.44 KiB) Downloaded 237 times
(150.13 KiB) Downloaded 237 times
(140.91 KiB) Downloaded 237 times
(155.19 KiB) Downloaded 237 times
(157.95 KiB) Downloaded 237 times
troy
Maxi Drive
Re: 109
#3 Post by troy » Tue Sep 22, 2020 7:56 am
(172.39 KiB) Downloaded 234 times
(193.11 KiB) Downloaded 234 times
(161.92 KiB) Downloaded 234 times
(140.77 KiB) Downloaded 234 times
(176.63 KiB) Downloaded 234 times
troy
Maxi Drive
Re: 109
#4 Post by troy » Tue Sep 22, 2020 7:58 am
(174.92 KiB) Downloaded 234 times
(169.57 KiB) Downloaded 234 times
(68.64 KiB) Downloaded 234 times
(211.84 KiB) Downloaded 234 times
(191.63 KiB) Downloaded 234 times
troy
Maxi Drive
Re: 109
#5 Post by troy » Tue Sep 22, 2020 8:00 am
(123.23 KiB) Downloaded 234 times
(129.51 KiB) Downloaded 234 times
(238.98 KiB) Downloaded 234 times
(254.4 KiB) Downloaded 234 times
troy
Maxi Drive
Re: 109
#6 Post by troy » Tue Sep 22, 2020 8:11 am
I couldn't drive my 88 in the winter after all the work and my 59 88 is beyond a quick repair so I decided that the 64 109 I bought for a parts truck for the sand 88 was salvageable . Starting June 28 we had a month curtailment due to the covid so I started pulling the 109 apart and started the rebuild . Wire wheeled the frame and repaired the rust , wire wheeled every leaf of the springs greased them put them back together . Pulled the diffs apart , new swivel balls, wheel brgs ,seals ,wheel cyls , brakes etc . Then the body work and paint . Ended up using the motor out of the 59 as it was rebuilt 4 years ago and the transmission out of the 109 . Reused the existing wiring harness , the 109 was last insured in the early 70s . So iam hoping the transmission will be good . Found a broken halfshaft when I took it apart so iam thinking the previous owner must have parked it back then and never repaired it . He passed away the 109 was towed to the wreckers where another rover enthusiast bought it for parts for his build and I bought it from him for parts for my build . I ended up using quite a bit of pieces off my 59 to complete it . Almost done now just the Koenig to go on and some little pieces , hopefully be driving it next week . Built it in 3 months , lot of hours and help from my wife and a buddy who's welder we used to repair the frame .
RobinS
Over Inflated
Re: 109
#7 Post by RobinS » Wed Sep 23, 2020 6:46 am
We all need a little help from our friends, I know I certainly did. Great job Robin
troy
Maxi Drive
Re: 109
#8 Post by troy » Mon Oct 05, 2020 6:02 pm
Almost finished , waiting for some small stuff to show up
(188.09 KiB) Downloaded 164 times
Colin
Mud Pit Boss
Re: 109
#9 Post by Colin » Mon Oct 05, 2020 10:12 pm
nice
cbalme
Slave Cylinder
Re: 109
#10 Post by cbalme » Mon Oct 05, 2020 10:57 pm
Well done! Time to get it dirty :D
