Greetings all - I am getting ready to fit new mains bearings to my '93 RRC LWB 4.2L . Any service or overhaul manual I can find states that the main bearing cap bolts are to be coated with the mystery lubricant "Marston EXP16A" - which seems to be NLA.
Any advice as to a substitute for EXP16A ? ARP Ultra torque assembly lube? Or just plain old 30W oil?
Lube for main bearing bolts 4.2L
rustneversleeps
- Apprentice
Last edited by rustneversleeps on Sun Dec 06, 2020 10:27 am, edited 1 time in total.
rgallant
Re: Lube for main bearing bolts 4.2L
The RAVE for the Disco 4.6 says engine oil I would imagine teh ARP would work fine
rustneversleeps
- Apprentice
Sounds good - thanks for your advice.
