Doing the brakes on a Disco 1
pathfinder
#1 Post by pathfinder » Mon Nov 12, 2007 4:47 am
I've done some looking around online, seems like changing the pads on my '95 Disco should be no big deal. Just two 12mm bolts holding calipers on, take out one and loosen the other and rotate caliper out of the way and use a c clamp to compress piston.
Am I missing anything?
Thanks!
bclandrover
#2 Post by bclandrover » Tue Nov 13, 2007 12:50 pm
Those instructions sound like they are for a Series 2 Discovery.
#3 Post by red90 » Tue Nov 13, 2007 1:46 pm
You don't need to remove the calipers to change pads. Pull retaining pins and the pads come straight out.
If you want to turn or replace the rotors, you'll need to pull the caliper and then the hub.
