natural gas conversion
rezdiver
- Master Cylinder
has anyone attempted a natural gas conversion to run both gasoline and natural gas on a fuel injected rover V8?
- Horn Blower
- Horn Blower
Nope... I've not seen anyone here do Nat gas. Other than illegaly taping into a house hold line I don't even know where you would get it. I guess there could be some vehical filling stations with it. The reall ticket would be to fill off of a house hold line but you would need a gas compresser to fill the tank as the line pressure is too low to do the job.
- Horn Blower
rezdiver
- Master Cylinder
- Horn Blower
rezdiver
- Master Cylinder
yes,
Nat gas uses High pressure cylinders rated for over 3000psi. and LPG uses tanks rated at around 500psi, big difference for storage, i have both sets of tanks here, just need the system, the Nat gas has a step down regulator also to reduce that much pressure. as for operating pressures i would guess they both range from atmospheric pressure(14.7 psi) to no more than 100 psi at max.
I have also heard that for dual conversions they take the intake manifold and plug in the nat gas injectors as close to the intake as possible while keeping everything else stock for the EFI injectors, kind of side by side.
basically on a dual gas you can swith fuels with a flick of a switch, you start the vehicle on gasoline and then swithch to Nat gas.
No recent experience, but I had a friend in the early 90s who powered a Dodge van with straight nat gas.
It seemed to work OK but was really gutless in an already gutless van, and was prone to hard starting in cool wet climate of Abbotsford. Perhaps if he could have had dual fuel and started with gasoline it would have been more successful. I can't remember if it was intended to be a single fuel system or if the gasoline side was just not working, but starting up with gasoline might be a good plan...
