I've just repainted my panels and had my capping re-galvanized. So, just wondering whether anyone ever puts anything between the two to protect the paint and seal better?
I was thinking of 3M protective tape, but maybe that's overkill and it doesn't matter if the paint underneath the capping is protected? //uploads.tapatalk-cdn.com/202312 ... fff2ed.jpg
Sent from my Pixel 8 Pro using Tapatalk
Protection btwn galvanized capping and painted panels?
steveep
- Little Wheel
cbalme
- Slave Cylinder
Re: Protection btwn galvanized capping and painted panels?
Land Rover never worried about it! I think it’ll be fine if everything is painted.
steveep
- Little Wheel
Fair point. Thanks, Colin!
Glenn D.
- Cross Member
I put a strip of wide plastic tape under mine, just to be sure. It riveted on with no problems. Also put it on the galvanized supports under the tub. Hopefully I will never have to take it apart again!
steveep
- Little Wheel
Thanks for the reply, Glenn!
I did end up purchasing some wide "corrosion protection" tape (meant for wrapping metal pipes that are buried in the ground) that I think I'll give a go in the same way.
