Was filling up the LT230 with the proscribed amount of gear oil... Tcase took all the oil, and none dripped out the fill hole up near the parking brake.
Question is: Is the amount of gear oil the book says to use correct? or should the gear oil be right up to the top of the filler hole as in a North American truck?
As always
JD
LT230 lube amount..
JD
Oil's well..?
John,
That is my gut feel... but that would just about fill the 230 to the top. Leaves little room for expansion/breathing.. ?? else? One heck of a lot of oil that would be. Wish I could be sure.
Rgds
JD
Rgds
JD
