Sweet Darlin' 1953 80" Station Wagon
InterMechanico
- Little Wheel
I've been keeping this one under my hat for a little while, but please meet my long term project!!! We're on our way back to town now. This is another Thormanby Island rover, and it definitely has sentimental value. The previous owner was a fantastic human being; very kind, old school type of person.
She is a 1953 80" Station Wagon. She's pretty much complete, and is an original Vancouver car. Was running when parked.
The engine turns; I believe it'll even run with some care, but it's not really driveable so why start it up. Engine parts are way too hard to come by!
Any advice on not botching this is appreciated. Rushing into it is out of the question. I've learned from old mistakes :roll:
Have a great weekend everyone!!
Roadqueen17
- Worm Gear
Re: Sweet Darlin' 1953 80" Station Wagon
Sounds great...any pictures would be appreciated by all!
InterMechanico
- Little Wheel
Absolutely impossible from the mobile phone, Friends!
However, give me a few moments...
InterMechanico
- Little Wheel
this will take a few
- (577.44 KiB) Downloaded 728 times
- (560.57 KiB) Downloaded 730 times
InterMechanico
- Little Wheel
a few more
- (404.26 KiB) Downloaded 717 times
- (389.74 KiB) Downloaded 727 times
- (424.52 KiB) Downloaded 723 times
InterMechanico
- Little Wheel
And a few more here
- (283.41 KiB) Downloaded 722 times
- (450.27 KiB) Downloaded 727 times
- (595.07 KiB) Downloaded 734 times
Very Nice, an Oldie but a Goodie as they say ...
RobinS
- Over Inflated
Never use the capstan fairlead roller as a towing hook. It will bend and or break
InterMechanico
- Little Wheel
Noted. Thank you Robin
InterMechanico
- Little Wheel
Following up on the project. I figure maybe some.of you could use a little good news and inspiration!
I began the teardown of the 80" this weekend, and should have everything done to major components by days end Sunday.
A couple of positives to mention:
The chassis is actually in really good shape, and is easily repairable. I'm obviously very happy about this. The awful rust I had thought I was up against is only 36" of the RH chassis rail just behind the fuel tank. The bulkhead outriggers, the forward fuel tank outrigger and the outer portions of the rear crossmember require replacement, but everything else is super solid :D
It looks as though all the driveline from engine to axles is original to the truck, and visually in absolutely stellar condition.
Chassis #36133407
Engine #36137081
Transmission #57100755 (early failure maybe?)
Front Axle #36137069
Rear Axle #36115xxx
Here are some pictures for you fine folks!
Chassis #36133407
Engine #36137081
Rear Axle #36115xxx
InterMechanico
- Little Wheel
Some pictures....
- (228.52 KiB) Downloaded 573 times
- (288.63 KiB) Downloaded 562 times
- (240.21 KiB) Downloaded 564 times
InterMechanico
- Little Wheel
And some more...
- (261.17 KiB) Downloaded 564 times
- (260.09 KiB) Downloaded 569 times
- (278.54 KiB) Downloaded 577 times
- (254.98 KiB) Downloaded 562 times
- (283.71 KiB) Downloaded 557 times
InterMechanico
- Little Wheel
And some more more....
- (287.58 KiB) Downloaded 564 times
- (250.22 KiB) Downloaded 563 times
- (317.71 KiB) Downloaded 578 times
- (314.36 KiB) Downloaded 572 times
InterMechanico
- Little Wheel
And some more more more...
- (261.41 KiB) Downloaded 571 times
- (294.22 KiB) Downloaded 578 times
- (344.08 KiB) Downloaded 572 times
- (325.24 KiB) Downloaded 570 times
- (318.51 KiB) Downloaded 577 times
InterMechanico
- Little Wheel
How about a couple more? 8)
- (311.54 KiB) Downloaded 574 times
- (286.94 KiB) Downloaded 561 times
- (297.45 KiB) Downloaded 574 times
- (250.6 KiB) Downloaded 580 times
- (290.57 KiB) Downloaded 571 times
InterMechanico
- Little Wheel
Some shafts and axles and stuff
- (170.95 KiB) Downloaded 574 times
- (295.54 KiB) Downloaded 576 times
- (324.85 KiB) Downloaded 574 times
- (297.04 KiB) Downloaded 583 times
InterMechanico
- Little Wheel
I cannot overstate how much Silver Grade Never-seez will be used during reassembly.
As far as chassis protection goes, I'm going with Coal Tar Epoxy. Works great, even in salt water.
InterMechanico
- Little Wheel
Cool to find an original Shelley LJ25 screw jack under the seat :D :D
I got it done; the easy part anyhow...
I can't believe how much of the hardware came out looking brand new, literally!
- (182.11 KiB) Downloaded 546 times
- (200.45 KiB) Downloaded 539 times
- (181.51 KiB) Downloaded 551 times
- (156.1 KiB) Downloaded 535 times
- (236.5 KiB) Downloaded 542 times
InterMechanico
- Little Wheel
Spring Shackle hardware...
- (271.95 KiB) Downloaded 548 times
- (238.09 KiB) Downloaded 560 times
RobinS
- Over Inflated
A really nice " unmolested "series one Julian . A great project. I know the capstan winch is far from a priority at this time but there is a guy in the series one club who has cast new fair lead brackets identical to the originals if you can't find one to replace your broken one.
Wilfpower
- Newbie
Wow! Looking forward to following the transformation! Thanks for all the pictures!!!
StuartL
- Horn Blower
Looks like another BC Government truck as it has straps across the front wings. I am currently redoing a '52 80 that was used by BC Forest Services and will finish it in period BC Forest Services Livery. It is great so many people are interested in the early Series 1's again. Slow and steady just like they are.....the LRSOC is a great resource.
Turton
- Little Wheel
Such a cool rover with great history. I will enjoy watching the restoration
Geoff
Geoff
webmaster
- Half Shaft
Reminds me of my '52 - 80" resto way back in 1996. Truck sat under a tree in the Okanagan from 1973 till I found her in 96. I poured some diesel down the cylinders and after letting it sit for a month, she started fine. Ran for several years before I rebuilt it.
Enjoy your rebuild!
InterMechanico
- Little Wheel
Thank you for all the advice, guys.
A few pictures of the frame repairs in progress.
A far cry from the 2 days I thought it would take, but coming along nicely...
I bought a new welder which really helped move things along. I have a bunch of welders, but they're mostly geared toward heavy projects, and are a little clunky working with 2 mm plate.
The model I got (slightly used, purchased from a friend) is the Fronius TransSteel 2200C multi-purpose. It does steel and aluminum MIG very well, DC stick and DC scratch start TIG which I havent tried yet.
- (228.83 KiB) Downloaded 386 times
- (298.92 KiB) Downloaded 381 times
- (234.92 KiB) Downloaded 371 times
- (225.2 KiB) Downloaded 373 times
- (219.41 KiB) Downloaded 378 times
Last edited by InterMechanico on Mon May 24, 2021 7:27 am, edited 2 times in total.
