FREE 109 military frame
Private Sales Only. Vendors/Dealers, pls use Vendors section. Sellers - Post must list the item(s) location. Pls mark post when items sold.
Forum rules
#1 Post by mepham55 » Thu May 17, 2018 7:51 am
I have a lead on a few 109” military frames. They will need some work on the frame horns but other than that they look solid. They will need to be hauled away, up a hill by hand so you’ll need helpers! Anyone interested? I’ll get some pictures today.
RamblerRob
Green Laner
Re: 109 military frames
#2 Post by RamblerRob » Thu May 17, 2018 5:05 pm
If anyone is thinking about grabbing one of these frames and cobbling together a project. Ive got 109 station wagon tub & safari roof. As well as coiler axles, suspension and running gear available if your feeling adventurous!
Where are the frames located?
#3 Post by mepham55 » Fri May 18, 2018 10:32 am
Frames are on a property in Saanich I’m helping clean up. These would be a great base for a 109 truck, they are very heavy duty compared with the civilian versions. Removable gearbox x members, extended spring mounts, etc....
franko
#4 Post by franko » Fri May 18, 2018 4:20 pm
Hi Matt and Rob, question I have a project 88” (Matt has seen) but really I’d rather a 109” if I got this frame could I slap together a 109 with Robs tub and my body from the seat box forward. Seems doable right 🤷🏼‍♂️
#5 Post by mepham55 » Fri May 18, 2018 7:59 pm
Hi Frank,
It’s possible, but not as easy as getting a new frame under your 88”! I believe Rob has a 5 door rear tub. Do you want a 5 door LWB or a 3 door LWB? I could find you a a good 88” frame if you want to go that route.
RamblerRob
Green Laner
#6 Post by RamblerRob » Fri May 18, 2018 8:07 pm
The big difference is the t post instead of just the sill rail on 88. T post includes thd b & c pillars for the station wagon . Also the second row floor which i have.
I think there is also a bulkhead behind your front seats which is different on a 109 SW.
I dont know what mounting points the frame has but they might be set up for the van type of rear body
franko
#7 Post by franko » Fri May 18, 2018 8:11 pm
Matt, yeah was thinking a 3 door 109. Anyway your probably right I should just focus on getting this 88” in good working order, I do love it.
Send me a pm, let’s find a good 88” frame for me then.
oldgravy
Captain Crunch
#8 Post by oldgravy » Sat May 19, 2018 3:17 pm
Hopefully these can be preserved...!
RamblerRob
Green Laner
#9 Post by RamblerRob » Sat May 19, 2018 3:25 pm
If anyone is thinking that getting these tidied up and galvanized would make a good start to a project, we are still looking for folks to dplit transport costs with to the mainland this summer
troy
Maxi Drive
#10 Post by troy » Fri Jun 01, 2018 3:48 pm
Rob sent you a pm . Troy
#11 Post by mepham55 » Fri Jun 01, 2018 8:12 pm
troy wrote: Fri Jun 01, 2018 3:48 pm Rob sent you a pm . Troy
Hi Troy,
If this PM was for me, I’ve havent received a PM yet?
Maggy57
Apprentice
#12 Post by Maggy57 » Sat Nov 17, 2018 8:11 pm
Hi know this is an older post but??? Are these frames still around I’ve got a 57 109 pickup with frame and bulkhead issues. thanks
#13 Post by mepham55 » Fri Nov 23, 2018 3:14 pm
I’ve got 1 military frame still. I’m not sure the series one 109” frame is the same as the later ticks though. The military frame is from a series 3 109”.
Landlover
Learner Driver
#14 Post by Landlover » Sat Jan 05, 2019 12:45 pm
Is there still one left? I have a 74 series 3...
Ryukyurvr
Junior Craftsman
#15 Post by Ryukyurvr » Wed Jan 16, 2019 5:37 am
I know I’m as far from anywhere as it comes but I have a series 3 RHD that needs a new frame is there one still left? And if so, where exactly is it?
#16 Post by mepham55 » Sat Mar 23, 2019 5:52 pm
FREE: Ex MOD 109 frame, needs to be moved ASAP or it will be chopped up and recycled. It will take 4 people to carry this frame from its current home. Must be picked up this month. Needs one frame horn repaired and some small rust areas treated. This frame is in VERY GOOD condition everywhere else, most of the original paint is still on it.
Tony4921
Re: FREE 109 military frame
#17 Post by Tony4921 » Sat Mar 23, 2019 6:51 pm
Where is it located Matt?
#18 Post by mepham55 » Sat Mar 23, 2019 7:49 pm
Tony4921 wrote: Sat Mar 23, 2019 6:51 pm Where is it located Matt?
Near the hartland landfill
oldgravy
Captain Crunch
#19 Post by oldgravy » Thu Jun 06, 2019 3:54 pm
I'm guessing it's gone?
