Painting a Chassis
- Washed Up
Painting a Chassis
Hi All,
Looking for some advice...
As some of you know I am rebuilding a Series 1 86" and this past weekend finally got the truck stripped to the chassis which is in remarkable shape.
All it will take is a little wire brushing to get the surface rust off. No need for sandblasting...although it would be nice, I just don't have the blaster...so straight to paint I will go.
The question is should I prime it with something, then apply a coat or tow of Tremclad or just go straight to the Tremclad?
Ideally I would like a paint that is thick enough to hide some of the imperfections in the chassis surface as Tremclad goes on fairly thin. I've thought of POR15 but it is fairly pricey and this rebuild is on a budget.
Any ideas????
Any ideas????
davran
A friend and I did my old MGB with POR15 and it's never rusted out. We used a wirebrush on a wheel and a hand brush whereever else I couldn't get. Every few years I hear from the present owner and rust isn't a problem.
POR15 is expensive but worth it IMHO.
I've heard that media blasting with nut shells is the best way to strip a frame, but I have no experience with this.
Series 1 chassis should be galvanized, no?
If you want to paint galv, then you need some really good prep and an etching primer.
Personally I've not found POR-15 very good. It is nearly impossible to prep well enough for it to stay stuck. I've gotten rust through in one season even with a sand blasted item. Running winter where they put gravel and salt on the roads is the real test and it failed on all accounts for me.
- Washed Up
Only the early pre-production 50 Series 1 80" had galvanized chassis from what I have read. Mine is definitely not galvanized.red90 wrote:Series 1 chassis should be galvanized, no?
I have heard both good and bad regarding POR15...As I have a garage, re-coating with Tremclad is the easiest as I have done this with both my now departed Series 3 and my current Defender. Yes you need to touch up once a year but that's no biggy in my book.
sailourboy
- Cross Member
TOLON
- Greasy Fingers
I've dome this type of work a couple of times. once on a series 1 107 and then on a 109 2A. What I did one the 107 was wire brush and apply a rust inhibitor/converter and paint over it with a General Paint enamel rust paint (General makes some awesome and tough commercial paints that can be brushed or rolled on).
On the 109 I had it media blasted then primed with a zinc-based primer and then covered with a two-part paint (Endura). In both cases I had the inside of the chassis waxoiled to reduce future rusting.
I've also painted steel sailboats using both Petit brand enamel marine paint and it gives a very smooth and durable finish applied with a roller then smoothed with a brush.
- Washed Up
Hi Dave,
I would treat it with Rust-Mort first, which does a chemical reaction to remove any surface rust that may be lurking around. Basically an inhibitor like Rob is suggesting. The finish comes out as a matt black, however this in itself will not protect against future rusting. Follow this with a good application of a high-zinc primer, then Tremclad or other rust paint.
Rust-Mort is available at Lordco.
- Greasy Fingers
I had the work done by a body shop... both times I looked into doing it myself as there are lots of recipes for warm chain saw oil and a toilet wax ring to DIY it but considering the awful mess it could make I decided it was worth having the body shop do it and keep my driveway, shop, wife's car and neighbourhood waxoil free. :D
- Washed Up
Thanks tonall for their thoughts...Dave why would you use a high zinc primer if the rust mort is an inhibitor?Dave wrote:Hi Dave,
Rust Mort is more of a killer/neutralizer. The high zinc primer acts as the new sacrificial coating that will oxidize before the steel does, and the paint on top is to resist oxygen getting at it in the first place.
However, all of this may be unnecessary based on the fact that we are only able to access the outside of the chassis, and not the inside. The only way to really do the inside is with hot dipped galvanizing on new metal, or wax oil (although not in the same league as galvanizing) to maintain or slow down the rust on the inside of older frames.
D
D
Hot dip for chassis
Dave,
Looks like your Christmas present (to your self) this year will be a visit to Silver City;
http://roverlanders.bc.ca/roverforum/vi ... ilver+city
Do it once, do it right! inside and out! :happy11:
LandyAndy
- Maxi Drive
Hi Dave,
My local body shop has quoted me ~$500 to blast & prime my 80" frame for me ready for repairs & the front spring conversion. I understand your on a budget but I think that the frame is one area that saving a few $ is just not worth it in the long run. The rust will come back at some point in the future if it's not completely removed from the outside of the frame.
Spend a bit more here & reap the rewards down the road with better resale value & less ongoing frame maintenance.
LandyAndy
- Maxi Drive
My local shop charges $150/hr for heavy blasting, that includes the blasting media, he didn't break the paint cost out as it was a 'budget' quote. Next nearest blaster is in Salmon Arm, so would need to add a 3hr round trip to go there.Bern B wrote:Dave
I had a 88" series II frame sandblasted at Mayfair Industrial for $175 and then hot dipped at Silver City for about $200 to $250
How much does paint cost?
good luck
Bernie
- Washed Up
As much as I would like to go the galvanized route...
This is a budget rebuild, and I am not planning on pulling the drive train or axles...at this point :? ...so rustproofing and painting will be the order of the day.
If in the future my son decides he really likes his Series 1 then he can pull it apart again and get the frame galvanized.
http://www3.telus.net/shade/Series%201/image008.jpg
I was examining it again today and really it is very, very solid with only lite surface rust. I will need to have some welding done, bulkhead outriggers and door posts...but that's about it.
I discovered today that there are quite a few shops that will inject waxyoil...so I will topcoat with something very resistant like POR15 and get it injected, but that will be it.
http://www3.telus.net/shade/Series%201/image006.jpg
My poor Defender 110 is feeling neglected, standing out in the pouring rain while this old interloper Rover occupies his garage spot... :cry:
Things I need to purchase...
Shocks all around
Brakes cylinders, and shoes (all)
Brake Lines
Master Cylinder
Misc. Springs, clips
New loom (probably will do my own or buy one from Autosparks)
Carb rebuild kit
All new track rod ends
...and I'm sure I will find some more bits and pieces that I need.
Things I still need to salvage from Donor Rover that is sitting in my driveway.
Carb
Fuel tank
Steering arms
breakfast- Rad-Shroud
RH Wing
Rear Tub
Roof and side Panels
...so you can see that I really need to get cracking and get the chassis sorted so I can start reassembling...
Thanks for all the suggestions they have been very helpfull.
Shocks all around
Brake Lines
Master Cylinder
Carb rebuild kit
Carb
Fuel tank
Steering arms
RH Wing
Rear Tub
- Landy Man
Hi Dave,
As much as I'm a big proponent of galvanizing I understand your desire for a Tremclad tune-up :)
Like Rob, I've had very good results with the rust converting products like "Rust Mort" followed by Tremclad gloss paint. The gloss has proven to be more durable than the matt finish in my experience. As he mentioned in an earlier post Dave Vervaet has just completed a restoration of his Lightweight chassis and it looks great. Dave V. had to do quite a bit of patching and grinding but the final Tremclad finish looks great. Dave B's comment about zinc primer is good advice but it's all a matter of degree on a fast and dirty resto IMHO.
Lots of Dave's in this thread :roll: thought I'd add my 2 cents.
Oh, by the way Dave F., thanks for the Login free photos!
- Washed Up
Red90...So you want to come and help me?red90 wrote:Yes, well, I can see where he is at and a few hours would have the rest of the bits off.rayhyland wrote:He is not stripping it all the way down. The drivetrain and axles are not coming off.
A few hours...ha...when was the last time you spent removing bolts from a 55 year old warhorse?
LandyAndy
- Maxi Drive
What..... it only takes a few mins with a zip disk :DDave_F wrote:Red90...So you want to come and help me?red90 wrote:
