I should be used to slow going. After all; I drive a 109.
The slow going is my recovery at home after an operation last Friday. Seems I'm supposed to do not much for a month. A week has gone by and I'm not even spending much time on the computer and haven't read any of the books I got to fill my time; very little TV too.
Less than an hour at a time at any of the TV, computer or visiting. A couple naps a day kind of round out the day. I think my project tomorrow will be to try to get going on that book again.
Slow going.
- Washed Up
Time heals all...
Greg seeing as you drive a 109 (as I do) taking things slow is part or your life (more people should try this).
Think of your recovery as breaking in a new engine...walk before you run...take your time, and try to enjoy the "downtime".
Hope all goes well and you are behind the wheel soon.
A fellow 109'er
A fellow 109'er
- Greasy Fingers
Hey Greg
Not sure I'd be recommending Rover metaphors to decribe health conditions... unless you are leaking on the floor alot... you're not leaking on the floor alot I hope. Then again, better a Rover metaphor than a Pinto! Get well soon fearless leader we need someone to set the standard at the Rally Wellie Toss in June!
ssortnarg
recovery and rehab
Hi Greg
If I bring you a 60lb drum of steel wool , will you have time to knit me a new injection pump for the endless project otherwise known as a 300tdi .
Hope the recovery goes well .
Ross Grant
Ross Grant
