Steep hill climb
rezdiver
- Master Cylinder
sailourboy
- Cross Member
PaulC
Doc Tari
Bermuda110
Doc Tari
The 110 driver is lucky he didn't land on his lid. I believe the inclination angle of the slope could be as much as 45 deg but that's not what the video shows. Pause it from ~ 10 sec and beyond and it looks more like 60 deg. This is were the creative camera work comes in. Nothing is going to hold on at that point, not even LR's TC or diff lock.
- Horn Blower
PaulC
Doc Tari
Any vehicle that can climb a 45 deg slope is pretty impressive and the new offerings from Rover seem to fit the bill. However, I'd be shocked if they (or any other make) will climb 60 degrees. Anyone have a T5 platform they would like to volunteer?
It would also be interesting to see if a "low tech" locker or LSD equipped truck could do the same.
sailourboy
- Cross Member
Doc Tari
N Hamelin
As Bermuda 110 mentioned, the poster of the 110 video calls it a 43-45 degree incline in his title:
"Land Rover Defender attempting Koos se Klim / Tsogwe at Moegatle [Just outside Brits in SA]. 43-45 degree incline."
Maybe they've actually measured it?
PaulC
T5 systems make easy work of this type of terrain not because it has a “locker” or 2, not because it has “Traction Control”....it is because these mechanical/electrical bits are entirely integrated. :idea:
Depending on what the driver selects; the system (& hardware) acts and reacts very differently.
For instance the “Locker/s” can provide infinitely variable lock, independently of each other. The locker (s) will back off when you turn the steering wheel... help keep you on line etc.
I could write a whole web site on the changing drive- train characteristics of the T5 and Terrain Response.....but suffice to say the abilities you see in videos like this are the product of this vehicles ability adjusting to the driver’s actions. :oops:
I could put almost anyone in one of these and drive up down very steep hills and side hills of 45 degrees all day as long & as they know the difference between right and left turn, brake and gas, stop and go I'll live to tell this tail. :)
Doc Tari
As I stated in a previous post, I have no doubt that the slope is 45 degrees (100%) and it's a pretty impressive demonstration. My point was that the videos of the RR and LR3 make it look much steeper (maybe 60 deg.), simply by "adjusting" the camera angle/perspective. If the slope was as steep as they make it look, I'd be very surprised to see the truck actually climb it.
N Hamelin
