Dear Roverlanders - it is with mixed feelings I am putting this on the market.
I bought a little over a year ago from a fellow member.
It has been as a daily runner. I have spent a lot of time enjoying upgrading and fixing it up. currently it is in tip top shape, thanks to the gang over at Don's (rovalution)
While the truck is terrific to use and comfortable both on highway and city - I'm increasing finding I really need a pick up for work.
And with a driveway jammed with a couple of motorcycles, a family car and a soon to be delved diesel pick up -- it is prudent to part with this even though I really want to keep it.
Below is the advert I put together for craigslist and some photos
I have had it listed for 25,000. on cragslist ( https://vancouver.craigslist.ca/van/cto ... 67614.html)
while it has recived lots of attention - the market not supporting the asking price
I am willing to sell it to a member for a lower price - around $21,500. - candidly this won't get me what I put in to this but ...
below is my blurb on the vehicle, and a list of work done to it..
photos can be viewed at https://www.dropbox.com/sh/dvyt9yl9gjm3 ... qZuDa?dl=0
PM with questions or call be directly 778.231.8847
jake fry
FOR SALE
1997 LAND ROVER DISCOVERY 300TDi 5SP Original Diesel, not a conversion! 249k Kms. No Rust. New Engine head work and engine overhaul completed by BC land rover specialist Rovalution in North Vancouver.
This is a rare find and a one off vehicle.
Imported from the canary island, this land rover is uncommon in North America, it is in excellent body and mechanical condition. This original factory built 5 speed 300 TDI, off-road classic is a basic European model free of lots of the North American electrical up grades, (no air bags, and minimal electronics). This is a proper vehicle with all the ability land rover is famous for. The rigorous service and maintenance done has made this truck ready for a major trip or lots of weekend adventuring. The ability of this Landrover is fantastic; in many ways it is like owning a defender at a fraction of the cost.
Included in the sale are 4 newish studded BFGoodrich tires, two new waterproof seat cover, cross members for the roof rack, a box of parts.
Below is a list of work done:
Engine:
(all parts either genuine Land Rover or Turner Engine replacement parts)
4 new Mahle Piston set, including rings and pins.
4 heavy-wall top hat sleeves.
New cinder head
Exhaust gas gauge
Cylinder Head 300Tdi New - OEM Valve Exhaust - PR2
Valve Exhaust - PR2
Gasket Set 300Tdi Decoke - OEM CYLINDER HEAD GASKET TDI - OEM Bolt Cylinder Head TDI - Oem
BOLT CYLINDER HEAD TDI - OEM
BOLT CYLINDER HEAD TDI - OEM Gasket Thermostat Housing 300Tdi - OEM STUD 10MM DOWNPIPE
Nut Flanges - Exhaust
Gaskets Exhaust Flange
Allisport highsport intercooler
New power steering hoses
New oil pump.
New oil pump cover.
Rod bearings.
Main bearings.
Land Rover brand rear seal.
All new timing cover seals.
New water pump.
New belts.
New thermostat.
New Radiator cap.
All new hoses. (see above)
All new belts. (see above)
Replacement Timing Case
12x helicoil installation to replace weak original studs in aluminum.
New Timing Belt.
New Timing tensioner.
New Timing idler.
New primary belt tensioner.
New Frost plugs.
4x Rebuilt fuel injectors.
New exhaust downpipe with old catalyst removed.
EGR cutoff kit.
New silicone intercooler hoses.
New throw-out bearing, clutch & pressure plate.
Heavy duty clutch arm.
fuel filter
Adjust Valves
cabin air filter
5 new tires BFGoodrich All terrain KO2
new front window regulator
usb port
Interior
head liner
New rear carpet
re- cushion seats
new driver door seal
new Skylight seals
re and re roof drains
new rear window seals
Machine shop work:
Polishing and balancing crank
Regrind camshaft
New rod small end bushings
Install 4 thick-wall top hat sleeves.
SOLD 1997 discovery original factory 300tdi 5 speed
