FS: Defender and the odd Series Parts
DBrands
Wing Nut
#1 Post by DBrands » Sun Nov 26, 2017 9:26 am
I've got a bunch of excess parts that I'd like to move on. Deals for purchase of multiple items. Parts are in Edmonton, but I'll be in the Fraser Valley from Dec 23 to January 1 for Christmas. Potential for some Rover Parts Underground Railroad work as well... Prices negotiable.
Engine:
SOLD NTC6660 - Mahle Air Filter - $15
SOLD Britpart Fuel Filter - $5
SOLD Power Steering Belts (2) - $5 each
SOLD Alternator Belt - $10
546799 - Diesel Pushrods ( All 8 ) - $25
ERR5263 - Elring 3-hole Head gasket - $20
ERR1208 - Manifold Gasket (2) - $5 each
STC1190 - Lift Pump - $25
ERR7293 - Timing Case Gasket - $5
Accessories:
SOLD Hella Fog Lights with adjustable mounts - $40
SOLD Land Rover branded speakers - $10
Used stock fuel gauge - $2
Used stock temp gauge - $2
SOLD Used stock clock - $2
SOLD New MUD UK Tunnel Tray - $60
SOLD New MUD UK Dash Console - $80
Bonnet Spare tire mount backing plate - free with the purchase of anything else
SOLDDefender 110 Fuel Cap Cover - $15
Sensor Connection EGT gauge mount - $5
395142- Series 3 Anti-Burst Lock 2 Barrels 2 Keys - $10
RTC3939 - Window Handle (2) - $5 each
SOLD STC439 - Used Indicator switch - $10
Various door and windscreen hinge bush/seals - $10 for all
Drivetrain:
Spring Isolators (6) - $20 for all, or $5 per
Drive Flange plastic caps (4 new, 2 used) - free with any other purchase
NTC7307 - Radius Arm Bushes (4) - $10
Clutch Spigot Bush and clutch fork bits - $5
Transmission to Bellhousing seals - $1 each
Not pictured:
OME 2764 - Lightly used Medium Duty D90 Rear Springs - $100
NRC9462/3 - (Not positive, but can confirm Part#) Standard HD D90 Rear Springs - $40
Anything I've missed pricing in the photo, make an offer!
(76.33 KiB) Downloaded 1627 times
(89.69 KiB) Downloaded 1627 times
The_Anachronist
Re: FS: Defender and the odd Series Parts
#2 Post by The_Anachronist » Sun Nov 26, 2017 3:13 pm
I'd be after having those fog lights and the little clock (Assuming it works?)
Where are you? I am Langley...
Edited: Duh. Just read your location. PM sent with my phone number. Call when Santa's sleigh pulls in to the Valley!
DBrands
Wing Nut
#3 Post by DBrands » Sun Nov 26, 2017 5:34 pm
The_Anachronist wrote:I'd be after having those fog lights and the little clock (Assuming it works?)
You're second in line for both. A fellow PM'd me about the lights and clock and is looking to have them shipped. Will let you know if he doesn't go for it.
rayhyland
Drip Dry
#4 Post by rayhyland » Wed Nov 29, 2017 8:38 am
You mentioned door seals. Do you have seals for the front doors on a Defender?
DBrands
Wing Nut
#5 Post by DBrands » Wed Nov 29, 2017 4:20 pm
rayhyland wrote:You mentioned door seals. Do you have seals for the front doors on a Defender?
I think that item listing might be a bit confusing. I'm referring to the small gasket type bits that fit between the hinges and the body panels or the brackets and the windscreen. Not the long soft rubber bits between the door and the cab. Sorry!
rayhyland
Drip Dry
#6 Post by rayhyland » Thu Nov 30, 2017 4:59 pm
Got it. Thanks!
