Hi Guys
This is a real rivet counter question.
I am finally getting around to installing a new cushioning strip (correctly this time) on top of the radiator support panel. This strip is held on with 10 pretty fancy split brass rivets. I believe the round part of the rivet goes down and the split part goes up and the 2 tangs are bent over to hold the cushioning strip on from the top side. Can any body confirm this?
Thanks Victor 1962 Dormobile
Orientation of brass split rivets on top of radiator panal
island dormy
- Drag Link
rayhyland
- Drip Dry
Re: Orientation of brass split rivets on top of radiator pan
I believe mine were opposite. The round head on top.
island dormy
- Drag Link
Hello
I posted this also on the series 2 club and received the answer that the tangs are on top. So I guess I will go with that. Those guys seem to know their old series rovers pretty well.
Thanks Victor
Thanks Victor
Don't cut the the strip too short - it is supposed to be pinched at the ends between the wing and the front panel. Extra points in the concours if done correctly.
island dormy
- Drag Link
Hi John
Thanks Matt Mepham also told me this and that's the way I will do it and rivet tails up.
Victor
Victor
