LEDs
Posted: Wed Apr 12, 2017 8:29 pm
Just installed new LED turn signals, brake lights, parking lights and a Number plate light. They look really nice!
http://i350.photobucket.com/albums/q401/colinbalme/D4EA284F-1883-4B2C-80DD-E8F1874B2410_zpsd1cjlyri.jpg
(Excuse the rusted rear crossmember)
I had a lot of trouble installing them, I had to make new connections since they were meant for a newer truck and I spent quite a while thinking they were duds until I checked my grounds and tested them with a 9v battery. I had an issue where both turn signals came on at the same time, but I had read somewhere else that if you removed the bulb in the dash it fixed the problem. (It did fix the problem) I also read that if you replace the bulb in the dash with a LED it fixes the problem, does anyone know where I can find one?
Oliver
Oliver
