help with oil spray out of oil filler filter
Turton
Little Wheel
#1 Post by Turton » Tue Jan 12, 2016 4:25 pm
Hello, I finally got my Rover safety inspected, all good, however driving home from the inspection and I now have oil sprayed all over the windshield ( I have the hood off ). The Oil appears to be coming form the oil filler filter. I have attached a photo. Am I missing anything? should there be a hose from vent on the head or?????
thanks
Geoff
(137.06 KiB) Downloaded 2000 times
Re: help with oil spray out of oil filler filter
#2 Post by red90 » Tue Jan 12, 2016 4:47 pm
Yes there should be hose and it should go to a port on the intake pipe.
Turton
Little Wheel
#3 Post by Turton » Tue Jan 12, 2016 4:55 pm
thanks for the reply, after looking at some pics online I see the hose your speaking of. I also see that some have a cap that looks like a radiator cap on the oil filler instead of a filter. see pic.
can I remove the filter?
Geoff
(102.28 KiB) Downloaded 1992 times
#4 Post by mepham55 » Tue Jan 12, 2016 5:55 pm
Your oil filler cap doesn't look original as well. It should be mushroom shaped with no gapping hole on the side, the venting should exit the bottomof the cap not the side. The one in the picture above is for later engines with sealed oil venting systems. I think I have an old style cap here.
Horn Blower
#5 Post by HeadDamage » Thu Jan 14, 2016 9:07 am
Sounds like you might have a bit much blow by in addition to an odd mix of caps.
Turton
Little Wheel
#6 Post by Turton » Fri Jan 15, 2016 8:01 am
blow by wouldn't surprise me, it is 50 years old. however the engine block has been painted by the previous owner, this means they had the engine out, I would "hope" they rebuilt it then.
Horn Blower
#7 Post by HeadDamage » Fri Jan 15, 2016 8:41 am
The latest setup removed the oil fill stand pipe and replaced it with a blanking plate on the block while also installing a (five main bearing) valve cover with a filler cap. (vented cap to intake)
http://13252-presscdn-0-94.pagely.netdn ... resize.jpg
Prior to that the stand pipe with the rad looking cap was used along with a valve cover cap like yours vented to the intake.
https://encrypted-tbn0.gstatic.com/imag ... XWakvB-b_w
Prior to that the stand pipe had a vented cap sort of like yours and a vented cap on the valve cover, both vented to atmosphere.
http://www.series123.com/UKhomepages/in ... engine.jpg
