Quick question regarding the fuel pump on my '95 RRC 4.2 County LWB. It's currently dead (Rangey as approx. 311,000km's) and looks like it has never been replaced. Either way, I'm looking at Rovers North, and they have a Proline pump for $99. Which is a fantastic deal! Anyways, they show it listed for a Disco I, but unsure of years, I assume pre '96? Either way, the link is below, and input on whether or not it will fit, would be fantastic. It states that it should, and if it is, it may make sense to find somewhere local.
http://www.roversnorth.com/ProductDesc. ... 132&type=0
Thanks!
Fuel Pump on a '95 RRC Question
punkinracer
Re: Fuel Pump on a '95 RRC Question
They are basically the same. The rangie one MAY be a little longer where the float assembly is, but these don't wear out so you could always just swap the guts from the new one in. Pretty simple really.
Pat
Pat
Discovery
Thanks for the response! That should be helpful to know.
The link you posted seems pretty clear as to the application:
Range Rover Classic from VIN MA464554.
Discovery I - Manual up to VIN VA714241, Automatic up to VIN VA546029.
