2.25
troy
Maxi Drive
2.25
#1 Post by troy » Fri Jan 03, 2014 8:05 am
does anyone know if or what the difference is between an early 2.25 3mbr block and a later 2.25 3mbr block ? i thought i read somewhere that the early motors had a cooling issue , and i think the early ones take a different water pump than the later motors but are the block castings the same ? thanks ..troy
