What brand(s) for valve-cover gasket sets are recommended for my leaky '01 D2?
Recommended valve-cover gasket set for D2?
nhay
Re: Recommended valve-cover gasket set for D2?
Seems like the valve covers all leak - mine certainly do. I remember reading that the bolts loosen with vibration, and you can't reach most of them to re-tighten.
Try using Norlock washers or Loctite. Not sure if there is a superior gasket available.
