Disco 3 TDV6
DBrands
- Wing Nut
Disco 3 TDV6
I was in a hurry and didn't get a chance to investigate further. I just saw the badges on the rear as stated above. Parked at UFV in Abbotsford. Left Hand Drive. Is it possible to get a Disco 3 TDV6 into Canada? Or is somebody just having fun with badges? If I see it again I will try have a closer look.
- (85 KiB) Downloaded 1922 times
franko
Re: Disco 3 TDV6
What the heck! Tell me more,I thought it had to be older then 15years to import.
That would be awesome to have,lhd would be even better.
Crs
- Missing Link
Re: Disco 3 TDV6
Nice! :D
If the engine went and the car needed a full replacement, would the diesel be any more expensive to transplant than a new Jag V8? It's not like the 3s use the Rover V8. Would there be any problems licensing it outside the AirZone?
franko
Re: Disco 3 TDV6
Rumor has it the TDV6 is under powered anyway, but still would be sweet.
LandyAndy
Re: Disco 3 TDV6
Think TD5 into a D2 but even worse..... you'd need a full vehicle as a donor to get all the parts plus maybe the loom.....Crs wrote:Nice! :D
