Heated Wind Screens
Heated Wind Screens
#1 Post by swamijake » Mon Jan 09, 2012 4:06 pm
I was able to drive the series one for the first real drive (Langley to Vancouver) and discovered the actual effectiveness of the factory demister. Anybody know where I can find a heated wind screen for a series one?
I'm waiting for a group buy with the LRSOC, but I expect that will take a while.
sailourboy
Cross Member
windscreen
#2 Post by sailourboy » Mon Jan 09, 2012 4:46 pm
Did you try a regular glass/windshield shop?
I think we used Speedy glass many years ago to replace one of the heated windows.
Ted
island dormy
Drag Link
Heated Window screens
#3 Post by island dormy » Mon Jan 09, 2012 8:02 pm
Hi.
Before you condem the rovers heater and defroster system, what style of heater does your rover have? A Kodiak or a Smiths?
My dormobile has a kodiak heater and was used in Alberta all year round and never had any problems keeping the front windows clear and the occupants warm. The Kodiak has a fresh outside air intake fed by a large 4 inch hose.
The round in shape smiths heater called a (shin burner) by the English sucks in stale humid interior air and simply recirculates it. If the floor boards are wet and slushy the fogging problem is even worse.
The stlye of defrost vent bolted to the windscreen also makes a huge differance . The Dormobile has large black metal vents and 2 inch hoses to distribute the windshield air. The smaller plastic vents fed by narrow 1 and 1/4 inch hoses do not deliver enough volume.. When you open up the cabin air vent the heater motor will speed way up showing how restricted this defrost system is.
Any way good luck with heated screeens if you go that route.
Victor
#4 Post by swamijake » Mon Jan 09, 2012 10:07 pm
Its definitely the little smiths. I wouldn't call it a shin burner, I'd barely call it a shin warmer. The area it defrosts on the windscreen is smaller than a medium sized pancake, not to mention having little to no impact on interior temperature, but that is probably due to the roof having a whistling gap between it and the wind screen. I am looking into some other heater options as well.
I tried calling Speedy auto glass, no dice.
rayhyland
Drip Dry
#5 Post by rayhyland » Tue Jan 10, 2012 10:43 pm
Have you tried carrying a squeegee in the cab with you?
#6 Post by swamijake » Tue Jan 10, 2012 11:13 pm
No, but I did have a roll of paper towel. It will have a squeegee for founders day.
rayhyland
Drip Dry
#7 Post by rayhyland » Wed Jan 11, 2012 8:24 pm
Perfect. I carry a squeegee in the 110 for really rainy days. Most reliable piece of kit in the truck...
Dave_F
Washed Up
#8 Post by Dave_F » Wed Jan 11, 2012 9:04 pm
I'm thinking that I will be looking at a secondary heater. They have some Decent ones down at princess auto, however I might need to change from the dynamo to an alternater.
#9 Post by red90 » Wed Jan 11, 2012 9:22 pm
Dave_F wrote:They have some Decent ones down at princess auto, however I might need to change from the dynamo to an alternater.
10.5 kW one on sale this month for $230. More heat than you will know what to do with....
http://rovers.red90.ca/Heater/
#10 Post by swamijake » Wed Jan 11, 2012 9:42 pm
Are you pulling air from the engine compartment? Is that kosher?
#11 Post by red90 » Thu Jan 12, 2012 7:22 am
I will be building an inlet duct in the next little while. There does not seem to be any downside other than the air can be warm, so in the summer it will be a problem. I'm currently just finishing off the main modifications to the dash venting.
larry emrick
Little Wheel
thoughts on "heaters"
#12 Post by larry emrick » Fri Jan 13, 2012 10:12 am
Discussion of the heating properties of those round Smith "heaters" with the neat little doors gave me my first smile of the day. My '64 Morgan has the same item. Morgan calls them fug-stirrers and they work beautifully - in the summertime.
But to expand on this thought, I have always wondered why in car heating was so pathetically poor on British vehicles even into the 60s. After all, their weather is not that much different than ours in the Lower Mainland and surely heater technology was not that difficult to figure out. But I guess in a culture where "put on another jumper" was the solution to lack of central heating, an effective heater in the car was considered a bit on the soft side.
My first car was a '54 Morris Minor and it simply would not start in the winter until I got a block heater but even that was defeated by a mid-60s Prince George winter after I left it parked outside the pub one night, and the in-car heater was totally useless. I had to use a window scraper on the INSIDE of the windshield.
My boss at the time had an Escort and on -30 nights he had to keep it running all night so it he could drive it in the morning and the doors contracted so much in the cold they would not close.
He finally got a VW with a gas-heater and that was bliss to drive in the winter. And the doors closed.
Oh for the good old days.
Larry Emrick
#13 Post by swamijake » Fri Jan 13, 2012 10:20 am
Ha! My mom has a 67 morgan and my dad has a 54 morris minor convertible. Is liking old british cars with pathetic heaters a genetic disease?
Horn Blower
#14 Post by HeadDamage » Fri Jan 13, 2012 12:23 pm
swamijake wrote:Ha! My mom has a 67 morgan and my dad has a 54 morris minor convertible. Is liking old british cars with pathetic heaters a genetic disease?
It could be... My folks used to drive me around in the back of assorted MG's
Re: thoughts on "heaters"
#15 Post by red90 » Fri Jan 13, 2012 12:33 pm
larry emrick wrote:He finally got a VW with a gas-heater and that was bliss to drive in the winter.
Until they stop working, which is 100% guaranteed to happen.
island dormy
Drag Link
Steamy windshields
#16 Post by island dormy » Sun Jan 15, 2012 6:58 am
Hi Dave
If you do add another heater you will have to switch to a alternater. I am still running a C-40 positive ground generator with the control box adjusted to the maximum limit (16.4 volts 22 amps.) I can run the heater and low beams okay. High beams and the heater cause the amp gauge to fall below 0 into the discharge area. So if a second heater is added there is no chance the generator will be able to keep up.
Steven Ford did the same heater modification on his series 1 the second heater was under the front seat box. It worked great.
Heres a couple of other things that might help. Check what degree thermastat is installed. I run a 180F all year with no problems. Has the heater core been reverse flushed with a garden hose?
Victor
roverwanabe
#17 Post by roverwanabe » Sun Jan 15, 2012 7:31 pm
#18 Post by swamijake » Mon Jan 16, 2012 6:41 am
I sent them an email, and they only have glass for series 2/3. They may do a run later this year for series 1, but nothing for a while.
Still looking.
Re: Steamy windshields
#19 Post by red90 » Mon Jan 16, 2012 7:11 am
island dormy wrote:Hi Dave
Or if you add a heated windscreen.
