Series III pick up cab on a 110?
Posted: Sun Jan 08, 2012 5:45 pm
by JS
Hi guys,
Would a Series III pick up cab fit on a 110?
Posted: Sun Jan 08, 2012 6:26 pm
Hi JS,
The dimensions would be very close but if you take a look through our Gallery and compare the top of the windsheild between a Series & 110 you will notice that the 110 windshield is higher than the doors & the roof curves down around the top corners of the windshield, where as the Series has no curve & is flat and square on the corners.
So I don't believe the Series Pick up cab will fit on a 110 unless you went with the Series Windshield also.
Cheers, Andy
Posted: Mon Jan 09, 2012 2:29 pm
by HeadDamage
Yes it will fit but you must use a series windshield and figure out something to do with the series windshield mounting/hinges.
Posted: Mon Jan 09, 2012 3:34 pm
by JS
Ok, thanks guys.
