Hi guys,
Would a Series III pick up cab fit on a 110?
Series III pick up cab on a 110?
Hi JS,
The dimensions would be very close but if you take a look through our Gallery and compare the top of the windsheild between a Series & 110 you will notice that the 110 windshield is higher than the doors & the roof curves down around the top corners of the windshield, where as the Series has no curve & is flat and square on the corners.
So I don't believe the Series Pick up cab will fit on a 110 unless you went with the Series Windshield also.
Cheers, Andy
Cheers, Andy
