My Disco 1
jeepingpw
Worm Gear
My Disco 1
#1 Post by jeepingpw » Sat Feb 26, 2011 1:40 pm
Not many posting pics of their projects so here's mine.
Rack was made last fall, but all else is from last few months.
Gas cans, gas can bars, & storage box come out & deer goes in.
Only problem is rear door can't open.
http://img.photobucket.com/albums/v493/ ... ure011.jpg
http://img.photobucket.com/albums/v493/ ... ure014.jpg
Front Driving lights
http://img.photobucket.com/albums/v493/ ... 011008.jpg
British DPM (Disruptive Pattern Material) seat covers
http://img.photobucket.com/albums/v493/ ... 011012.jpg
Fire Extiguisher mounted to floor drivers door
http://img.photobucket.com/albums/v493/ ... 011011.jpg
Took out the "coin box" for my Sirius receiver & the ash tray for 2 more light switches.
http://img.photobucket.com/albums/v493/ ... 1014-2.jpg
Made a rnd bar hold down for the jack
http://img.photobucket.com/albums/v493/ ... 1003-3.jpg
Bought a 18ft RV awning, had to build a 2x4 rear carrier to get it home.
http://img.photobucket.com/albums/v493/ ... 1004-1.jpg
Magnaflow stainless steel muffler & aluminized 2 1/2" tail pipe.
http://img.photobucket.com/albums/v493/ ... naflow.jpg
Kuhmo M/T's 225's on factory rims
(Have Firestone winters on factory wheel as well)
http://img.photobucket.com/albums/v493/ ... 1018-1.jpg
Today a 2" lift on the hottest day this summer!
Was very easy to put in.
Left the Front Shock Towers in.
Only had to remove the;
Front Brake line brackets (2 nuts),
Fr & Rr sway bar bushings.
Front didn't have Coil Retainers on the bottom?
The goodies (Front Diff gaurd another day)
http://img.photobucket.com/albums/v493/ ... isplay.jpg
Front before
http://img.photobucket.com/albums/v493/ ... before.jpg
Getting enough droop, used factory jack.
http://img.photobucket.com/albums/v493/ ... lepush.jpg
Front after
http://img.photobucket.com/albums/v493/ ... rafter.jpg
Rear before
Rear after
http://img.photobucket.com/albums/v493/ ... ug1003.jpg
Gave me 2 1/2" of lift, will have to wait to see after it settles.
Before
http://img.photobucket.com/albums/v493/ ... ure002.jpg
After
http://img.photobucket.com/albums/v493/ ... ug1013.jpg
sailourboy
Cross Member
#2 Post by sailourboy » Sat Feb 26, 2011 7:08 pm
Nice setup, only question I would have , is what is the tong weight the hitch receiver will take?
ted
jeepingpw
Worm Gear
#3 Post by jeepingpw » Tue Mar 01, 2011 7:51 pm
The rack is rated at 500 lbs.
Its a little wobbly with 2 - 5gal cans & box that wieghts about 100lbs.
I've had it out 3 times in the bush & haven't bent anything, yet!
I had a similar one (but bigger) on a '82 bronco. I had side bars go from the ends to the bumper that stiffened it up. I may do this to this one.
Only thing I don't like about it is you can't open the rear door.
A small price to pay for a budget build.
gudjeon
#4 Post by gudjeon » Wed Mar 02, 2011 10:46 am
Gotta love Princess Auto!
jeepingpw
Worm Gear
#5 Post by jeepingpw » Fri Aug 05, 2011 9:32 pm
Edited old post today.
