Series Aux Fuel Valve/Gauge Wiring and Setup
adesteiguer
Apprentice
#1 Post by adesteiguer » Mon Feb 15, 2010 7:49 pm
Anyone have the correct wiring setup for an aux fuel valve and switches for a Series?
Cylinder bore
#2 Post by John » Thu Feb 18, 2010 8:50 am
Are you looking to wire in the military style valve into a dual tank set-up? It is pretty simple. The valve redirects the fuel flow from one tank to the other and at the same time the integral switch re-routes the ground connection from the fuel gauge to the sender in the appropriate tank.
Do you have the required hardware? Is one particular aspect of the install giving you trouble?
