RR ECU Board
sailourboy
Cross Member
RR ECU Board
#1 Post by sailourboy » Wed Nov 17, 2004 1:28 pm
Does anyone know where the ECU hides in a 91 RR?
SB
bclandrover
#2 Post by bclandrover » Wed Nov 17, 2004 2:45 pm
Which one?
sailourboy
Cross Member
#3 Post by sailourboy » Wed Nov 17, 2004 9:25 pm
The one for the cruise control.
Thanks Don!
Ted
bclandrover
#4 Post by bclandrover » Fri Nov 19, 2004 10:25 pm
Now, where is that bugger on those trucks...
...ETM says "Drivers side above lower dash panel"
It may also be handy to know...
...part number may be printed on it, PRC5060, I believe the unit is black.
Has an white(?) 8 pin connector plugged into it.
Pin 1 - white with yellow, supplies power from cruise switch (fuse C5 - 10 amp).
Pin 2 - red with white, input from set/accel switch.
Pin 3 - purple with green, cancel signal from brakes, via relay.
Pin 4 - black with red, vaccum pump motor control
Pin 5 - yellow, speed input.
Pin 6 - blue with white, input from reset/decel switch.
Pin 7 - black with yellow, vaccum vent control.
Pin 8 - black ground.
Good luck!
Later,
Don
sailourboy
Cross Member
#5 Post by sailourboy » Sat Nov 20, 2004 9:41 am
Thanks Don!
