Just thought I would post some pics of my conversion from a rebuilt diesel with no pump to a gas 2.25. Thanks to Tony for the head and his spares and time. JD for the shipping and Hopefully Greg for the 5 head bolts to get this thing running!
the paint adds 10 HP :roll: :wink:
http://i126.photobucket.com/albums/p90/ ... ead003.jpg
I suppose the head gasket is an ellring brand? I heard britpart is not the greatest.
http://i126.photobucket.com/albums/p90/ ... ead004.jpg
http://i126.photobucket.com/albums/p90/ ... ead005.jpg
http://i126.photobucket.com/albums/p90/ ... ead006.jpg
the 5 head bolts that go through the rockers. DOH
http://i126.photobucket.com/albums/p90/ ... ead007.jpg
The diesel puch rods and rockers are much shorter. Diesel on the top.
http://i126.photobucket.com/albums/p90/ ... ead008.jpg
Thanks for viewing!
2.25 to 2.25
cheapo
Major update! :thumbleft: She runs! OKay heres the run down. The diesel cam (2.25) has to be rotated 10 degrees. Basically time it like you would a gas cam. The hayes book defines it well. I have both books and looked at the differences.
LIFT
gas are both .257"
Diesel
inlet - .262"
Exhaust - .279"
Now thats a huge difference. The valve springs just about bottom out but they are still free moving when you handcrank it. also with the 8:1 head the dosn't hit the piston.
The other differences are the openings and closing. All the diesel cams are 10 degrees retarded. Example: Gas opens the inlet at 6* BTDC and closes at 52* ABDC. Diesel Opens the inlet at 16* BTDC and Closes 42* ABDC. However the exhaust on the diesel opens at 51* BBDC. Gas opens at 34* BBDC. This has not made a impact from what I have found out yet. The Gas cam Advance Is covered by advancing the Diesel cam 10*. As said above Just move the flywheel it 0-6* BTDC, take the tensioner off and line up the cam sprocket with the timing cover bolt hole, as explained in the Hayes manual.
With that all out of the way, The other differences are the Starter. Much bigger on the Diesel. Its in the way of the exhaust. Other than that the only other thing I have had to change is the gear for the Distributor. She Fired right up after we figured we were out 180*.
Thanks Again to Tony Klassen, JD and Greg Sutfin for Helping me out getting the Gas head and parts and knowledge
worked till 10PM outside.
http://i126.photobucket.com/albums/p90/ ... G09002.jpg
I put some asbestos blanket over the starter to keep it cool
http://i126.photobucket.com/albums/p90/cabsover78/th_LandroverrunningAUG09003.jpg
http://i126.photobucket.com/albums/p90/cabsover78/th_LandroverrunningAUG09005.jpg
Still have a long way till I can Insure it but this is a huge step forward! Thanks for reading.
LIFT
gas are both .257"
Diesel
inlet - .262"
Exhaust - .279"
