Does anyone have a 200 tdi pump timing kit around town? I want to change my water pump and might as well do the timing belt as well.
Its a disco 200 tdi.
Dave? what did you use?
THANKS...
GLENN (hopefully going to moab) Daigle
pump timing
Glenn D.
- Cross Member
Glenn D.
- Cross Member
I thought I was the only one that used drill bits. Gotta find one that fits quite snugly in the hole.
A few other things that also assist when reassembling...
MAKE SURE YOU ARE ON TDC BEFORE YOU TAKE THE BELT OFF. FIND THE MARKS, CLEAN THEM, HIGHLIGHT THEM
A digital camera, taking several close up shots of exactly where the fuel pump bolts are tightened
A hammer and chisel to add your own additional marks to the timing cover just so you know exactly how it goes back together.
cheers, Dave
cheers, Dave
