Disco 4.0 to 4.6
96whitedisco
Disco 4.0 to 4.6
#1 Post by 96whitedisco » Sun Aug 10, 2008 7:30 pm
Hi everyone!!
Just wanted to say a few words about my conversion. My 96 Disco Is now running a 2004 4.6  that I had rebuilt.The only problem you will run into Is the timing cover on the 4.6 Is deeper pushing all your pullys forward and not leaving the right amout of room between the rad.You will need to use your old, or by a new 4.0 litre timing cover and your old oil pan.I have just got back from my annual tour De BC with my wife her friend the two dogs and Alot of wine the truck averaged about 410 to 470 KM a tank of fuel, I managed to never spend more than a $1.50 per litre.If you are looking for more power, this Is the way to go. YOU WONT BE DISAPIONTED.I would also like to thank Alister at HESP for doing the work, this man has helped me out time and time again.CheersAndrew
nakedbarra
Mud Pit Boss
hmmmmmmmm
#2 Post by nakedbarra » Sun Aug 10, 2008 8:15 pm
Hi Andrew welcome to the 4.6 conversion Club as I did this a few years ago with my 93 classic and I love it as well, its just a shame its parked in the shed for now :cry:
Andrew
96whitedisco
#3 Post by 96whitedisco » Sun Aug 10, 2008 11:17 pm
Well I have just over 2000 k on the engine now and I think she Is broken In.
The bottom end on these engines Is amazing I look forward to installing the headers when they arrive, I'm currently running a custom exhaust that I will have to scrap when the headers go on. As I have seen the guys in California running the dual set up.....oh well!!!!
Im hoping I will have all the bugs worked out for the last trip to Whipsaw.
Andrew
tony
Little Wheel
#4 Post by tony » Wed Aug 13, 2008 12:15 pm
I've read some where that you can shorten the intake pipes (sorry I don't know their technical name) in the plenum chamber by 1/2 " and see a dramatic increase in horse power can anyone confirm that ?
96whitedisco
#5 Post by 96whitedisco » Wed Aug 13, 2008 3:04 pm
May be, the intake plenum pipes inside the black housing, this may give better bottom end but the 4.6 doesn't have a problem with bottom end power as my rear locker locks up now on pavement and my front drivers wheel spins when I give it.....
