Rear window washer jet tubing
PaavScan
#1 Post by PaavScan » Fri Apr 13, 2007 9:08 am
Hi Rafterman
Steps listed below are from the Rave service mamual.
Hopefully you can reteive the tubing wthout taking off the rear interior door panel.
Stuart S
REAR WINDOW WASHER JET
Service repair no - 84.30.09
Remove
1. Turn washer jet in a clockwise direction to
release it from the rear quarter panel.
2. Remove rear quarter/speaker trim panel.
3. Feed washer tubing through rear quarter panel
to allow removal of washer jet.
4. Remove washer jet from tubing.
Refit
5. Reverse removal procedure. 1 to 4.
NOTE: The tubing run from the reservoir to
rear door washer jet differs between left
and right hand drive vehicles. On right
hand vehicles the tubing run is on the left hand
side of the roof. On left hand drive vehicles, the
right side. See Description and operation,
Windscreen Wiper and Washer Operation
