Hey,
I looked into cutting the fenders on my disco when I was doing the lift and tire thing.
I started with a 1.5 inch body lift, and then a 2" OME lift. I bolted up a set of 33x10.50R15's BFG Muds with offset wheels and it still rubbed. So, out came the clippers and I did the "camel trophy" cut which is to take a short section of the rear corner fender out for the tire to clear.
There are several articles on discoweb including some extreme cutting which I considered but didn't bother with in the end.
Later,
DOn
sawzall to fenders?
bclandrover
- Landy Man
I cut my disco in the manner Don described, just about 3/4 of an inch off the rear lower trailing edge of the rear wheel arch tapering the cut as you come up, ending the cut as it fairs in to the first curve. I used a slightly worn hacksaw blade in one of those holders that only grabs one end of the blade. I was careful and masked the good side and was able to get a nice cut without disturbing the paint. A little emory cloth to smooth the cut edge and get the burr of the backside, followed by a little black sealer paint on the very edge and you couldn't even tell that it was ever cut unless you looked very close :spinning:
Which reminds me, I have a picture of mine (although it was a 1991 3 door which may be different). But it is 245/75/16.
http://members.shaw.ca/jbarge/reartrim.jpg
A little off topic, but I hated those tires....
