Suspension mods?
Suspension mods?
I'm just wondering if anyone on here is going nuts with thier coil sprung suspensions or if they are just doing the tried and true OME spring and shock route?
PaavScan
Right now I have 90HD rear springs (230lbs/in) in the front and OME781's (290lb/in) in the rear and that gives me about a 1.5 to 2 inch lift over stock. My 90 has a 2.5NA diesel and winch up front so she needs heavier front springs than a NAS 90. I'm running 255x85R16 tires on 130 rims. All else is stock but I'm temped to try some of the wizzy stuff ;)
bclandrover
96whitedisco
Im running the heavy duty OME springs on my 96 disco and I have the pro comp 9000 on, I did have the pro comp 3000 on but found them a little soft.
I was told that the stock 3000 will support a lift up to 2".
Pro comp really nows there stuff too bad they dont make a full suspension for any Landrover
Andrew
Andrew
bclandrover
