Series 109 Parts: Side Sills (Deep), E-brake lever assembly, ...
steveep
Little Wheel
#1 Post by steveep » Wed Oct 01, 2025 8:39 pm
Off of a '62 SIIa 109 two door (whether they started there or not, who knows!).
The sill are relatively straight with solid brackets but the PO cut a section out of the top folded edge on both sides (to fit aftermarket door seals maybe?) and there's one (known) small rust hole on one side. $80
The e/park brake lever assembly has pitting under the paint, but is solid, the button operates well and I installed a new catch pawl. It looks like the PO modified the arm that it ultimately rotates down at the other end of the whole mechanism - but you might either not need that bit or might have access to a welder yourself. I could fix it, but I don't have an original one to compare it to (or the rest of the park brake system to see what it has to operate). $50
Photos can be found here: https://photos.app.goo.gl/L2Qu2qx23yDgwees5
Also have a 109 hard top and sides, a heater box or two, a set of rear double benches and a set of rear single seats, and more - but haven't had a chance to drag them out for photos yet.
Will be at Founders Day.
