Another dumb alternator question
Posted: Wed Aug 06, 2025 3:37 pm
by Canadman
Purchased an alternator for my series 2a and have the bracket on but the alternator doesn't fit the bracket snugly as the Pic shows. The gaps on either side of the alternator where it bolts on are quite a bit larger than the opening on the bracket. I purchased what I thought was the correct alternator and I'm pretty sure the bracket is the correct one. What am I missing???
Re: Another dumb alternator question
Posted: Fri Aug 08, 2025 12:40 pm
by cbalme
Hi Canadman, as you tighten the rear bolt that collar snugs up to the back of the bracket I believe.
A little hard to tell what the bracket looks like from the photos but I believe that it was a 2.5 na diesel bracket that was on the engine
Posted: Fri Aug 08, 2025 3:50 pm
cbalme wrote:Hi Canadman, as you tighten the rear bolt that collar snugs up to the back of the bracket I believe.
It is very clearly the wrong size.
What alternator did you buy?
Posted: Fri Aug 08, 2025 4:16 pm
by Canadman
red90 wrote: Fri Aug 08, 2025 3:50 pm
I bought the Lucas alternator from 3 Brothers. Assumed it was the correct one as its listed as a correct size for the 2.25l engine. Any idea what alternator I SHOULD be looking for?
(26.88 KiB) Downloaded 48 times
Posted: Fri Aug 08, 2025 8:51 pm
by cbalme
Can I see a closeup of the bracket. That alternator should work fine!!
Posted: Sat Aug 09, 2025 11:44 am
by Canadman
cbalme wrote: Fri Aug 08, 2025 8:51 pm Can I see a closeup of the bracket. That alternator should work fine!!
Here
(139.69 KiB) Downloaded 39 times
Posted: Sat Aug 09, 2025 11:45 am
by Canadman
(108.23 KiB) Downloaded 34 times
Posted: Sat Aug 09, 2025 3:44 pm
I believe the bracket mounting width should be 80 mm and the alternator a few mm wider. Measure both and report back.
Posted: Sat Aug 09, 2025 4:46 pm
by Canadman
Dont have a metric ruler handy but here is it in inches
(82.52 KiB) Downloaded 28 times
(100.37 KiB) Downloaded 33 times
Posted: Sat Aug 09, 2025 5:46 pm
You need to measure the outside of the bracket. The alternator goes on the outside.
Posted: Sat Aug 09, 2025 6:36 pm
by Canadman
(81.38 KiB) Downloaded 33 times
red90 wrote: Sat Aug 09, 2025 5:46 pm You need to measure the outside of the bracket. The alternator goes on the outside.
Posted: Sat Aug 09, 2025 6:56 pm
Look like it fits to me. Your first picture is misleading.
Posted: Sat Aug 09, 2025 7:01 pm
by Canadman
red90 wrote: Sat Aug 09, 2025 6:56 pm Look like it fits to me. Your first picture is misleading.
There's a 3" distance between the outsides of the bracket and over 3 1/2" gap between brackets on the alternator. Waybtoo.much of a gap.
Posted: Sat Aug 09, 2025 7:04 pm
Umm. No.
3-1/8” and 3-3/8”. The sliding collar takes up the 1/4”.
