Another dumb alternator question
Canadman
- Three Wheeler
Purchased an alternator for my series 2a and have the bracket on but the alternator doesn't fit the bracket snugly as the Pic shows. The gaps on either side of the alternator where it bolts on are quite a bit larger than the opening on the bracket. I purchased what I thought was the correct alternator and I'm pretty sure the bracket is the correct one. What am I missing???
- (54.71 KiB) Downloaded 62 times
cbalme
- Slave Cylinder
Re: Another dumb alternator question
Hi Canadman, as you tighten the rear bolt that collar snugs up to the back of the bracket I believe.
A little hard to tell what the bracket looks like from the photos but I believe that it was a 2.5 na diesel bracket that was on the engine
It is very clearly the wrong size.cbalme wrote:Hi Canadman, as you tighten the rear bolt that collar snugs up to the back of the bracket I believe.
What alternator did you buy?
Canadman
- Three Wheeler
I bought the Lucas alternator from 3 Brothers. Assumed it was the correct one as its listed as a correct size for the 2.25l engine. Any idea what alternator I SHOULD be looking for?red90 wrote: Fri Aug 08, 2025 3:50 pmIt is very clearly the wrong size.cbalme wrote:Hi Canadman, as you tighten the rear bolt that collar snugs up to the back of the bracket I believe.
cbalme
- Slave Cylinder
Can I see a closeup of the bracket. That alternator should work fine!!
Canadman
- Three Wheeler
Herecbalme wrote: Fri Aug 08, 2025 8:51 pm Can I see a closeup of the bracket. That alternator should work fine!!
- (139.69 KiB) Downloaded 39 times
Canadman
- Three Wheeler
I believe the bracket mounting width should be 80 mm and the alternator a few mm wider. Measure both and report back.
Canadman
- Three Wheeler
Dont have a metric ruler handy but here is it in inches
You need to measure the outside of the bracket. The alternator goes on the outside.
Canadman
- Three Wheeler
red90 wrote: Sat Aug 09, 2025 5:46 pm You need to measure the outside of the bracket. The alternator goes on the outside.
Look like it fits to me. Your first picture is misleading.
Canadman
- Three Wheeler
There's a 3" distance between the outsides of the bracket and over 3 1/2" gap between brackets on the alternator. Waybtoo.much of a gap.
Umm. No.
3-1/8” and 3-3/8”. The sliding collar takes up the 1/4”.
