I purchaesd a OBD2 reader the other day, as my check engine light comes on about once a week.
The code was po441 when i looked in the book it came up with this.
EVAPORATIVE EMISSION CONTROL SYSTEM INCORRECT PURGE FLOW.
What the hell does that mean?
Andrew
CHECK ENGINE CODE
Fault code 441.....
Hi Andrew,
I use this site to check on fault codes,
http://www.robisonservice.com/servicede ... e.asp#1996
I see the code you are referring to under European codes???
I'm not too sure what the explanation is regarding to, maybe Don could help you out? Otherwise maybe a call to LR of Richmond would help??
Apart from the light, what other symptons are you seeing?
Good luck,
Good luck,
