Prop shaft , speedo and door pocket panels
Bargrip
Junior Craftsman
#1 Post by Bargrip » Thu Feb 02, 2023 11:08 am
Just cleaning out a few things..
Exmoor trim door pocket panels( 1 pair) new never used.. should fit any sliding window rover. charcoal grey $70
2 New genuine never fitted LR FRC 8393 prop shafts, gkn u joints ..( Defender 90. 300/td5 ) for rear. $65 Each
Speed in miles missing rubber button, but works perfectly fine..$10
Can deliver from Nanaimo to Vic.
Cheers.
Henryk.
(85.94 KiB) Downloaded 204 times
(78.97 KiB) Downloaded 204 times
(58.36 KiB) Downloaded 204 times
(74.98 KiB) Downloaded 204 times
(100.81 KiB) Downloaded 204 times
StuartC
Wing Nut
Re: Prop shaft , speedo and door pocket panels
#2 Post by StuartC » Thu Feb 02, 2023 2:41 pm
Hi Henryk
I'll take the door pocket panels please.
I'm in Courtenay.
Stuart
Bargrip
Junior Craftsman
#3 Post by Bargrip » Thu Feb 02, 2023 2:53 pm
Ok, Stuart
They are yours..
I might even be able to meet you up there..
Just have to check my work schedule
StuartC
Wing Nut
#4 Post by StuartC » Thu Feb 02, 2023 4:26 pm
Thank-you
Well that would be a possibility.....you can give me some moral support on the restoration to this point on the '59.
I'll PM you re payment options.
Stu
