I am disassembling my 1963 2A SWB and converting it to an EV. For sale is the engine, radiator, oil air filter and various other engine ancillaries. I will be keeping the transmission. The fuel system and exhaust is also available.
The original engine was seized and so this is a 1967 which the team at Three Brothers Land Rovers set to work for me. Bunch of new parts.
Located in Esquimalt, BC. I have very limited abilities to deliver. The engine should be out in the next week or so. I apologise but I suspect I know very little about this type of engine compared to the people here on the group....slowly learning. I'll try and answer question the best I can.
I was told 1500$ is a good price.
Recent work on engine:
EM-NRC2054 Engine Mounting Rubber with Nuts - Gas 2.25L & 2.6L
EG-274171 Exhaust/Inlet Manifold Gasket 4cyl 2.25G & 2.5G 90/110
SE-IEMBLTKIT Inlet and Exhaust Manifold Stud and Bolt Kit for 2.25L Gas
EF-ERC2886 Carburetor Zenith 361V Replacement Series 2a-3 2.25L 68-84
EF-587684 Fuel Pipe Short Connecting Fuel Line to Zenith Carburetor
EE-RTC3571G Spark Plug Champion N9YC 7:1 CR 2.25/2.6L Series 2-3
EE-587701LR 2.25L 4 Cyl Ignition Lead Set Ser 2a 61-70 Push-In LR Gen
EE-PRC9858 Ignition Coil Non-Resistor Type, 4 & 6 Cyl 1967-84 (Neg. Grd)
EE-RTC3270 Ignition Contact Points Fixed for Lucas DM2P4/25D4/6 '54-76
EE-RTC3472 Ignition Condenser 1954-76 2.0/2.25L 4 & 2.6L 6 Cylinder
EF-549761 Fuel Pump with Glass Sediment Bowl 2.25L Gas w/Gasket
EC-STC3758 Water Pump Assembly Series 2A/3 2.25L 9-Hole w/Gasket
Installed good used intake/exhaust manifold, new carburetor, fuel line, gaskets where required. Installed new plugs, ignition wires, points, condensor, coil. Replaced fuel pump. Test ran engine, set timing. Replaced water pump. Re-tested and road tested.
(sold) Working 1967 2.25 L Engine (Vancouver Island, Esquimalt))
pblarose
- Junior Craftsman
- (336.21 KiB) Downloaded 236 times
- (326.87 KiB) Downloaded 236 times
Landydoni
- Junior Craftsman
Re: Working 1967 2.25 L Engine (Vancouver Island, Esquimalt))
I'm interested.
Email sent.
Email sent.
